IBASSO DX200 HiFi DAP 32bit/384kHz DSD512 DUAL ES9028PRO Balanced
IBasso DX200 HiFi DAP 32bit/384kHz DSD512 DUAL ES9028PRO Balanced
The iBasso DX200 portable music player is a DAP that succeeds in offering the same level of audio resolution as a high-end 32-bit Hi-Res Hi-Fi audiophile streamer with the flexibility of a smartphone interface under Android 6.0. Equipped with two DAC ES9028PRO iBasso shows once again that it is the master on board also offering a nomadic DAC on battery without concession.
By buying this product you get 98 loyalty points
Reference : 11710
989,00 €tax incl.
824,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
iBasso DX200
iBasso DX200 Baladeur HiFi DAC 32bit/384kHz DSD512 ES9028PRO x2 Balanced
The iBasso DX200 portable music player is a DAP that succeeds in offering the same level of audio resolution as a high-end 32-bit Hi-Res Hi-Fi audiophile streamer with the flexibility of a smartphone interface under Android 6.0. Equipped with two DAC ES9028PRO iBasso shows once again that it is the master on board also offering a nomadic DAC on battery without concession. Finally, here is the replacement for the legendary iBasso DX100 in a superb aluminium case with a non-destructive 64bit bit digital volume and fully symmetrical analog stages.
Android 6.0 OS, 4.2" reactive touchscreen, 4400mAh battery
iBasso is a master in the user experience. The iBasso DX200 features a 1280X768 touch screen on a fast Android 6.0 application with an eight-core couch and 2 GB of RAM. It is smoothly flowing and totally intuitive.
Open to the world with its Bluetooth, Wifi and reversible C-type USB port with XMOS U208 chip, the iBasso DX200 allows applications to be installed on the Google Play Store. This way you can read high definition files from Qobuz, Tidal, Spotify and Deezer playlists perfectly integrated in the OS. This high-end DAP will be an ally of choice in all situations requiring the ultimate in mobile reading.
2X ES9028 PRO 32bit 384 kHz DAC and USB XMOS U208
Much more than just an audiophile, the iBasso DX200 offers a conversion section that rivals the best DAC Hifi systems on the market. Its dual ES9028 Pro conversion chip (one per channel) provides all the necessary capacity from the smallest subtle information from an opera to DSD 512 to the most energetic hard rock to DXD PCM 32bit 384kHz. This truly symmetrical scheme offers unparalleled dynamics on a DAP.
The two precision Femto second clocks are original Accusilicone clocks used in particular for Hifi Gustard Audio electronics. Thanks to its Jitter eliminator and Hyperstream system level, the two ES9028Pro conversion chips provide a crystal clear, musical sound of the highest level.
A fully balanced analog stage
A high quality digital section is nothing without a good analog output. The DX200 offers a fully symmetrical scheme from the DAC to the 2.5 mm Balanced jack output. Thanks to its high output level from 3V to 6V, it offers a dynamic capacity rarely encountered on a DAP. The quality of the passive components is raised to the highest level with ESR capacitors with low discharge, resistances to 0.05% on a 6-layer gold-plated circuit.
The very high precision AOPs do not lose any of the original signal with an output level of 6V on the balanced outputs. The DAP DX200 features a dedicated line output for Hifi systems, an output for classic headphones on 3.5mm jack and an output with balanced amplification on 2.5mm jack for reference headphones (Audeze, Sennheiser).
iBasso DX200 Input & Outputs
1SPDIF Mini Jack Coaxial / Mini Toslink output
2USB-C 32bit 384kHz XMOS U208 input
3Balanced Jack 2.5mm 6V headphone output
4Jack 3.5mm 3V headphone output
5Jack 3.5mm 3V line output
6Micro SD card slot (max. 512Go)
iBasso DX200 review on Head-Fi.org
" A fantastically wide sound stage coupled with excellent instrument separation and imaging makes the DX200 truly a joy to listen to. "
Test du iBasso DX200 sur Head-Fi.org
Product typeDAP
DAC2x ESS ES9028Pro
ProcessorRK3368 core
Clock2x femtoclock Accusilicone
Memory for OS2Go
Digital input1x Asynchronous USB-C XMOS U208 32bit 384kHz (Driver Thesycon)
Digital outputs1x Mini Coaxial / Mini Toslink 24bit 192kHz
USB OTG / USB DAC 32bit 384kHz
Analog outputs1x Headphone Jack 3.5mm
1x Single-Ended Jack 2.5mm
1x Line output Jack 3.5mm
Wireless connectivityWiFi
Bluetooth 4.0
Sampling ratePCM up to 32bit 192kHz
DSD up to DSD512 Native via USB and Micro SD
Frequency response20Hz - 20kHz ±0.16dB
Line output level, single-ended output3Vrms
Balanced output level6Vrms
SNRLine output / Jack 3.5mm : -122dB ±1dB
Jack 2.5mm Balanced output : -125dB ±1dB
THD+N0.0002% @ -110dB
EqualizerYes
Digital volume without loss150 Step
Bit-Perfect playbackYes
Digital filterSlow Roll-Off
PCM Sharp
Batterie capacity4400mAh
Touchscreen4.2" IPS, 768 x 1280px
Internal storage capacity64Go
Max Micro SD storage512Go (Micro SDcard sold separately)
Supported formatsAPE, FLAC, WAV, WMA, AAC, ALAC, AIFF, OGG, MP3, DFF, DXD, CUE, M3U8
Play Store AppsTidal, Qobuz, Spotify, Deezer
Housing materialAluminium
Dimensions128 x 69 x 19.5mm
Weight240g
Package1x iBasso DX200
1x Leather cover
1x USB-C Cable
1x Burn-in balanced cable
1x Coaxial cable
InputWiFi
OutputOptical Toslink
OutputCoaxial SPDIF
OutputBluetooth
OutputJack 3.5mm
OutputJack 2.5mm
DAC / ADC ChipES9028PRO
Max sampling rate384kHz
Max sampling rateDSD512
The iBasso DX200 portable music player is a DAP that succeeds in offering the same level of audio resolution as a high-end 32-bit Hi-Res Hi-Fi...
