SHANLING M0 HiFi DAP Compact Music Player DAC ES9218P 32bit 384kHz DSD Black
Shanling offers with its M0 a digital player high fidelity extremely compact with original aesthetics. But the Shanling M0 is also a concentrate of technologies and features to offer you high definition sound, wherever you are!
Reference : 12767
99,00 €tax incl.
82,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
This product has been replaced by the new version, the SHANLING M0 PRO DAP DAC 2xES9219C.
Shanling M0
DAP Compact Hifi Player DAC ES9218P Black
Shanling M0
Shanling M0
A DAP that fits in the palm of your hand
The first thing that is obvious with this Shanling M0 is of course its particularly small size. Designed to follow you in all your movements, without cluttering you, the DAP measures only 40 x 13.5 x 45mm. On the weight side, the M0 weighs only 38g. So it will easily be forgotten so you can fully enjoy your music.
However, Shanling makes no concessions on ergonomics and integrates a beautiful 1.54" high definition touch screen from LG. This will allow you to simply access your music and act on all available settings. A screen placed behind a curved tempered glass window and components protected by a superb 100% Aluminium CNC machined case.
Shanling M0 un DAP compact
An intelligent interface
If Shanling takes great care in the aesthetics of its product, this desire to offer a product that is both beautiful and easy to learn is on the software side with the MTouch OS operating system. Thus, the interface of the walkman allows a fast and easy navigation, and an easy access to the numerous functionalities.
Shanling M0 Interface
Shanling M0 ES9218P
A technique at the service of sound
On the sound side, the M0 incorporates a DAC ESS ES9218P. This will allow a quality Digital / Analog conversion in full transparency. A converter associated with a powerful amplification section and an analog volume control. A combination that allows this small DAP to offer 118dB SNR, 0.004% distortion and support sample rates up to 32bit 384kHz, for accurate and detailed reproduction.
In addition, this walkman embeds a multi-layer PCB, allowing it on the one hand to take advantage of a smaller size of 38% compared to its big brother the Shanling M1, and on the other hand to have a cleaner electrical circuit and thus limit interference on the signal.
Unlimited connectivity
If the Shanling M0 of course has a Jack 3.5 connector to connect it in a classic way to your headset, it also offers connectivity Bluetooth for more comfortable use. Bluetooth connectivity with Sony LDAC and Qualcomm aptX technologies. This first technology, LDAC allows to enjoy Bluetooth Hi-Res Audio files, up to 24bit 96kHz 4.5Mbps, where traditional Bluetooth would allow only 16bit 44.1Hz compressed. The second technology, aptX, allows a transmission with less latency and more stable, in order to restore a clean signal.
But more than that, the M0 benefits from a bi-directional Bluetooth 4.1. Thus, if it can transmit to a speaker or a headset, it can also serve as a receiver, in order to benefit from its amplification and its DAC, from a third source.
Shanling M0 Bluetooth
Shanling M0 USB C
USB-C bi-directional
In the same vein, this walkman also offers a bi-directional USB-C port. Like Bluetooth, it will therefore be able to receive or send audio data. Ideal for enjoying the audio performance of the device.
A battery to follow you everywhere
The DAP integrates a battery of 630mAh for an autonomy of 15h in reading, and days in standby. Perfect for enjoying your music without interruption during all your travels.
Shanling M0
DACESS ES9218P
Output power80mW @ 32Ω
Recommended headphone impedance8 - 300Ω
Frequency response20Hz - 20kHz (-0.5dB)
Distortion0.004% (500mV)
SNR118dB
Output impedance0.16Ω
Channels resolution70dB
Dynamic range> 105dB
Up to 32bit 384kHz / DSD128
Supported formats
DSDDSD64, DSD128 (.iso, .dsf, .dff)
DXDUp to 32bit 384kHz
APEUp to 24bit 192kHz / 16bit 384kHz
FLACUp to 24bit 192kHz
ALACUp to 24bit 192kHz
WAVUp to 32bit 384kHz
AIFF/AIFUp to 32bit 192kHz
DTS-
Supported formats with lossessMP3, WMA, AAC, OGG, ALAC, MP2, M4A, AC3, CUE
Dimensions40 x 13.5 x 45mm
Screen1.54" 240 x 240px High Definition
Weight38g
Autonomy15h
Standby autonomy30 days
Charging time2h
Battery630mAh
StorageMicro SD up to 512Go (not included)
OutputJack 3.5mm
InputMicro SD
OutputJack 3.5mm
OutputBluetooth
DAC / ADC ChipES9218P
Max sampling rateDSD128
Max sampling rate384kHz
Génial !
Un mini lecteur qui a tout d'un grand : une qualité sonore excellente dans un format aussi réduit, s'en ai presque magique. Et a un prix sommes toute très contenu. Un excellent pas dans le monde de l'audiophile, avant de partir sur des DAP plus haut de gamme et entrainer notre oreille :)
This review has been posted for SHANLING M0 HiFi DAP Compact Music Player DAC ES9218P 32bit 384kHz DSD Black
Shanling offers with its M0 a digital player high fidelity extremely compact with original aesthetics. But the Shanling M0 is also a concentrate of...
