SHANLING M1 White DAP High Fidelity DAC AK4452 32bit/192kHz DSD
4.5 / 5
11494
139,00 €tax incl.
115,83 € tax excl.
Available
Shipping date: 16-01-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
shanling m1 DSDThe famous Shanling brand here unveils the DAP M1 Nomadic High Fidelity Walkman Bluetooth 4.0 APTX.
Designed around a sober and elegant design at the same time, its compactness brings in a pocket-sized audiophile sound.
Ideal for mobile listening, this full-fidelity player offers you the possibility to play virtually all PCM high-resolution audio files up to32bit 192kHzor DSD 64 and 128.
In addition, the analog part features an original ALPS potentiometer for increased reliability and sound fidelity.
This DAP uses a converter32bit AK4452192Khz latest generation as well as a high performance headphone output MAXA97220the result of which is a great musicality. Its very ergonomic design, its careful electronics makes it a successful product that represents an alternative to larger digital players.
Of course this player is alsoDAC OTG.
Features:/ Strong>
  • Screen: 2.35 "TFT (360x400)
  • Support DSD: Supported and converts to PCM by software channel
  • Bluetooth receiver: Version: 4.0 APT-X
  • DAC conversion component: AK4452
  • Amplification chipheadphone: MAX97220
  • Two-level gain (high / low)
  • Supported formats: APE, FLAC, ALAC, WMA, AAC, OGG, MP3, WAV, AIFF, DSF, DFF
  • Supported sampling frequencies: 44.1-192 kHz
  • Headphone output power: 35mW @ 32Ω
  • Bandwidth: 20Hz to 20kHz (-0.5dB)
  • Distortion: 0.006% (A-weighting, 500mV output)
  • S / N:> 105dB (A-weighting)
  • Dynamic capacity:> 105dB
  • Output Impedance: 0.1Ω
  • Channel separation> 70dB (1 kHz)
  • Jitter: 30ps (Typ)
  • Reference clock: 200 femtoseconds
  • Battery: 950mAH, 9-10 hours of operation (manufacturer data), 3-4 hours of charging
  • OS: Windows XP, 7, 8, 10 (32/64 bit), Mac OS X 10.7 and above
Connectors:
  • USB: Type-C
  • Headphone output: 3.5mm jack
  • Micro SD card reader: 1 TF (up to 200GB)
Dimensions and weight:
  • Width: 60 mm
  • Depth: 12.8 mm
  • Height: 50 mm
  • Weight: 60g
  • White Colour
  • Comes with 3 screen protectors / 1 USB-C cable to USB-C 15cm
Hi-Res Audio Certification Shanling M1
shanling m1 DSD
Casque Shanling M1
Casque audio Shanling M1
Casque Shanling M1
ComponentAK4452
MaterialAluminium
ColorBlanc
StructureAluminium
Channel2 channels (Stéréo)
Colissimo - TNT - SoColissimo
2 reviews
Un petit bijou !
Malgré toutes les illustrations du site et les vidéos sur le produit ce n'est qu'à l'ouverture de la boite que l'on réalise que ce M1 est un vrai bijou. Très bien fini et surtout très petit et léger mes premières écoutes de musique très diverses me confortent dans le sentiment qu'il remplacera très agréablement un viel iPod Classic à bout de souffle.
Merci à Audiophonics de me l'avoir fait découvrir (et de l'avoir livré dans un temps record !)
Un seul commentaire: le descriptif mentionne plusieurs câbles USB-C mais la boite n'en comporte qu'un seul (USB-C USB-A)
This review has been posted for SHANLING M1 White DAP High Fidelity DAC AK4452 32bit/192kHz DSD
Lecteur fun
C'est un petit bijou de conception et fabrication, idéal en nomadisme pour celles et ceux qui veulent s'encombrer un minimum, sans se priver notemment d'un bel écran. Attention cependant, tout ici est fin et précis mais petit ( les commandes aussi ) et s'il remplira très bien son rôle à l'exterieur, il ne conviendra pas forcément à une écoute posée et plus exigente en terme de rendu sonore mais aussi de confort d'utilisation. C'est un petit Dap en adéquation avec son prix.
