Pourriez vous s.v.p. m'indiquer si ce produit convient pour charger une power bank usb à partir d'un petit panneau solaire ? Merci !
8/35V to 5V 15W 3A USB-A Female
This DC / DC converter can receive an input voltage of 8-35V and output a voltage of 5V 3A 15W. It has a pre-soldered female USB-A connector at the output.
Compact and cast in a moisture-resistant epoxy resin, it will allow you to obtain a clean and stabilized source of energy.
It is particularly suitable for mounting in a car, to enjoy a USB connector.
Input voltage | DC 8V-35V |
Output voltage | 5V 15W 3A |
Output connector | USB-A Femelle |
USB connector holes spacing | 29mm |
Dimensions | 46 x 32 x 18mm |
Weight | 62g |
Output voltage (V) | 5.0 |
Input voltage (V) | 8.0 |
Input voltage (V) | 24.0 |
Input voltage (V) | 17.0 |
Input voltage (V) | 35.0 |
Input voltage (V) | 10.0 |
Input voltage (V) | 26.0 |
Input voltage (V) | 19.0 |
Input voltage (V) | 33.0 |
Input voltage (V) | 12.0 |
Input voltage (V) | 28.0 |
Input voltage (V) | 21.0 |
Input voltage (V) | 34.0 |
Input voltage (V) | 14.0 |
Input voltage (V) | 30.0 |
Input voltage (V) | 23.0 |
Input voltage (V) | 16.0 |
Input voltage (V) | 32.0 |
Input voltage (V) | 9.0 |
Input voltage (V) | 25.0 |
Input voltage (V) | 18.0 |
Input voltage (V) | 11.0 |
Input voltage (V) | 27.0 |
Input voltage (V) | 20.0 |
Input voltage (V) | 13.0 |
Input voltage (V) | 29.0 |
Input voltage (V) | 22.0 |
Input voltage (V) | 15.0 |
Input voltage (V) | 31.0 |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
BOUBOUR J.
