CANARE L-4CFB High performance Digital cable 75 Ohm shielded Ø6.1mm
CANARE L-4CFB High performance Digital cable 75 Ohm shielded Ø 6.1mm
Reference : 13289
1,33 €tax excl.
Available
Shipping date: 20-06-2019.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Cable sold by the meter
canare cable per meter
CANARE L-4CFB Coaxial Cable
This coaxial cable meets stringent mechanical and electrical specifications to be a 75ohm coaxial cable high quality with extremely low loss rates.
Designed and manufactured in Japan by the famous firm CANARE, this coaxial cable 75 Ohm L-4CFB was originally dedicated to the professional broadcast market. It responds also to SDI standards (SMPTE259M, 292M, 424M).
TypeCoaxial cable
Coax SpecificationRG-59
nominal impedance75Ω
Capacitance55pf / m
armouring100% aluminum foil
tinned copper braid
Drivercopper solid
Sheath6.1mm
Dielectric3.7mm
Ratio speed spread79%
Attenuation ((dB / 100 m ± 0.1 dB)10MHz: 3dB / 100m
135MHz: 9.7dB / 100m
270 MHz: 13.9dB / 100m
750MHz: 24.3dB / 100m
1.5GHz: 36dB / 100m
3GHz: 54.3dB / 100m
Nominal diameter0.9mm
conductor diameter0.8mm
AWG conductor20AWG
insulation diameter3.7mm
Colissimo - TNT - SoColissimo
