CANARE LV-77S High performance Digital cable 75 Ohm shielded Ø7.7mm
CANARE LV-77S High performance Digital cable 75 Ohm shielded Ø 7.7mm
Reference : 11709
4,80 €tax incl.
4,00 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
This coaxial cable LV-77S was designed and manufactured in Japan by the famous company CANARE, it has very high quality and was originally dedicated to the professional broadcast market.
Its notoriety is no longer to be done and the cables of the firm did not take long to penetrate the HiFi market as their quality of manufacture is impeccable.
It has the peculiarity of having high quality mechanical and electrical characteristics and is among the 75 ohm coaxial cables with extremely low loss rates.
This cable can work perfectly with the RCA 75 Ohm crimp connector CANARE RCAP-C5F .
Characteristics :
  • Bare copper conductor
  • Section: 0.326mm² (22AWG)
  • Insulation: PE Polyethylene
  • Shielding: Straps 100% Aluminum / Copper & Aluminum braided
  • Dielectric Strength: 1000V AC / 1min
  • Nominal impedance: 75 Ohm
  • Rapid spread: 66%
  • Total cable diameter: Ø 7.7mm
  • Sold by meter
Diameter (mm)7.7
Length (m)Sold by length
Number of conductors2
Insulation materialPE
ShieldingYes
Section (mm²)0.32
Ground / ShieldingYes
2 reviews
6 mètres de de câble vrai 75 ohms
Pour recâbler toute mon installation. Facilité de montage et résultat parfait, pour un prix basique, avec une connectique amphenol au top et de jolies gaines viablue pour le repérage des câbles. Look et finition pros avec un son superbe . Du sérieux!
This review has been posted for CANARE LV-77S High performance Digital cable 75 Ohm shielded Ø7.7mm
le meilleur des Canare coax spdif
au dessus des canare coax. Pas de brillance. Il est la reference en asie dans le milieu high end. Je confirme apres test que ce soit en sortie d'interface XMOS208, Amanero ou CM6631A, toutes isolées galvaniquement en sortie sur le coax par transfo Pulse (important pour ne pas fausser le test)
