NEOTECH NEI-3003 MK III Coaxial cable UP-OCC Silver Plated Ø8.5mm
NEOTECH NEI-3003 MK III Digital coaxial cable UP-OCC Silver Plated Ø8.5mm
4.8 / 5
Reference : 11606
21,90 €tax incl.
18,25 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
NEOTECHhas long been the leader in cable production using UP-OCC "single crystal" copper developed by Professor Ohno of the Chiba Institute of Technology in Japan. The UP-OCC is pure to 99.99998% and is considered the "ultimate" of drivers used to date.
Thecoaxial digital cable NEI-3003 MK IIIis made of UP-OCC copper conductors and insulated in double layer polyethylene. It produces a very balanced and natural sound, notably thanks to its braided copper armor andtp: //www.audiophonics.fr/fr/gaines-au-metre-c-238.html "target =" _ blank ">sheathmade of PVC.
The loss of signal is almost non-existent thanks to the shielding and isolation process used by NEOTECH. Their expertise and know-how are felt in terms of manufacturing and sound performance.
Features:/ Strong>
  • Copper conductors UP-OCC99.99998% Plain: Silver Plated
  • Insulationof drivers in PE: high mechanical strength ensures perfect maintenance of tight strands between them
  • Shielding in copper braid
  • Red PVC sheath
  • Total diameter: Ø 8,5mm
  • Sold by the meter
Neotech NEI-3003 MK III
Caractéristiques Cuivre UP-OCC
Diameter (mm)8.5
Length (m)Sold by length
Number of conductors1
Insulation materialPE
ShieldingYes
Section (mm²)N/A
Ground / ShieldingYes
8 reviews
Great sound upgrade, NOT 75 Ohm !!!
Excellent build quality, fine sound upgrade for interconnection type...but it is not 75 Ohm cable like was in description before my order...well not so suitable for digital coax type cable construction.
This review has been posted for NEOTECH NEI-3003 MK III Coaxial cable UP-OCC Silver Plated Ø8.5mm
Excellent coaxial
Câble acheté pour mettre entre mon Shanling Tempo en drive et mon R7 et ça marche du feu de Dieu. Question montage je lui ai mis des rca Elecaudio TE-RC90S en cuivre tellurium argent. Le câble passe au chausse pied dans les connecteurs, 8.5mm tous les deux, mais après juste une soudure au milieu et le reste se coince tout seul autour. J'ai bourré avec du teflon après pour éviter tout risque. Non rodé il pulvérise un bon modulation et j'attends avec impatience la fin du rodage. Bien à vous ;)
Remarquable !
Je confirme l'excellence de ce câble en liaison numérique, en association avec des prises RCA VIBORG VR109G.
L'ensemble a largement battu un Van Den Hul "The First Ultimate" quand même (ce que n'est pas parvenu à faire le pourtant excellent NEOTECH Nemoi 3220, en liaison DAC - amplificateur).
Très belle analyse, avec une beauté sur les voix sans sifflante et des aigus très riches, jamais durs ni cassants. Belle scène sonore 3D aussi.
Un excellent câble en liaison numérique.
Son rapport qualité prix / écoute est imbattable !
Coaxial cable neotech
Excellent coaxial cable, tested on cd mechanics, network streamer, with excellent results.Neutral cable, excellent instrumental separation, excellent voice definition, excellent 3d.The cable immediately sounds good, but I recommend at least 20/30 hours of running-in. That at this price you can not find better. Tested on a high level system. Highly recommended.
Excellent cable
Aussi performant que des câbles beaucoup plus cher
