XMOS Digital interface USB to SPDIF TCXO 24bit / 192kHz
XMOS Digital interface USB to SPDIF TCXO 24bit/192khz
4.7 / 5
Reference : 10548
129,00 €tax incl.
107,50 € tax excl.
Available
Shipping date: 21-09-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
This interface based on the now famous XMOS U8 allows to have digital outputs of high level in SPDIF coaxial and optical with an Asynchronous management of the USB.
Mid-range version of our interfaces, this model is equipped with 2 high precision TCXO clocks (0.1ppm) gold-plated.
Limited to 24bits 192khz on its SPDIF outputs, this interface allows the DIYers to recover the I2S format via the I2S connector on the PCB (in this case this interface supports the 384khz).
Recognized without drivers under Mac-os and linux (including most solutions for Raspberry PI) this requires a Windows Driver (Click here)
STARTERS
USBUSB-B x1
EXITS
I2Son PCB
CoaxialsPDIF
ToslinkOptical x1
Features:/ Strong>
  • Case 100% Aluminum
  • Compatible with Raspyfi, Volumio, Picoreplayer
  • Jitter: 4.6 ps
  • TCXO Gold-plated x2 (0.1ppm)
  • Coaxial / Optical: From 44.1K 48K 88.2k 96K 176.4kHz 192K up to 24 / 192K
  • I2S: Up to 32bit / 384K
  • Power: USB
  • Dimensions: 68 x 33 x 88mm
  • Supplied without USB cable
  • Color: Titanium
  • Weight: 185 g
Colissimo - TNT - SoColissimo
2 reviews
performant
sincérement, ameliore vraiment la qualité de l'écoute, plus précis, scène sonore etc... je le conseille à la majorité, qui comme moi ont un systéme d' entrée de gamme, attention je ne dis pas que c'est le jour et la nuit, non, mais pour celui qui connait son système hifi vous entendrez la difference.
Alors je ne met que quatre, car l' interface est difficilement reconnu sous runeaudio, obligé de bidouiller.
raspi avec runeaudio et interface branché sur alimentation linéaire
mydac et ampli marantz pm63 et davis matisse.
C'est toujours mieux de savoir sur quel ensemble cet avis s'est forgé.
This review has been posted for XMOS Digital interface USB to SPDIF TCXO 24bit / 192kHz
Très bon
Comparée à une utilisation en entrée directe USB à mon ampli/DAC (de qualité : 384kHz et horloge interne de haute précision), je progresse en précision (définition), en douceur (moins de duretés numériques, sur les voix notamment) et en scène sonore qui gagne un peu de profondeur.
Bien sûr, il convient de l'utiliser avec des câbles de qualités si l'on veut profiter au maximum des possibilités de cette interface. Puis de l'isoler des vibrations en lui collant de petits pieds en caoutchouc et le poser sur une surface bien dense par exemple.
Au final, pour un investissement relativement modeste, vous pourrez améliorer de très sensiblement à sensiblement, selon les performances de votre DAC, le rendu musical de votre Hi-Fi.
