DAC Module AKM AK4497EQ I2S SPDIF 32Bit / 384kHz LT1963 Regulator
AKM AK4495EQ DAC Module S/PDIF 192K/24B USB384K/32B Regulators 2xLM2941CS
This DAC will allow you to link all your digital players to your channel via the digital interface or via a USB module to submit an analog signal specific to your audio installation.
4.6 / 5
Reference : 12706
159,00 €tax incl.
132,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
AKM Ak4497EQ
DAC Module USB DSD Native Coaxial Optical Regulators LT1963 & 2x LM2941CS-1A, OPA LME49710NA
Module DAC AK4497EQ
Build, upgrade, optimize your DIY systems
This module AKM AK4495EQ will offer you the opportunity to evolve your DIY creations to enjoy an ever higher sound quality.
This will allow you to link & nbsp; all your digital players to your channel via the digital interface or via a USB module to submit an analog signal specific to your audio installation.
Puce DAC AK4497EQ
High quality DAC
Equipped with a 32-bit AKM AK4497EQ DAC, this module takes advantage of the famous Velvet Sound architecture. This makes it possible to develop sound details that are usually too far back to be audible by limiting the distortion. Added to this a 32 bit digital filter, this architecture allows the reading of PCM files up to 384 kHZ.
The AKM AK4495EQ chip is mostly a DSD native decoder, so it's an ideal choice for high definition enthusiasts.
This is a high-end system that remains very accessible.
Advanced components
LT1963 regulator
This DAC benefits from precise regulation thanks to a voltage regulator LT1963 accompanied by a torque LM2941CS-1A. Each of these components is individually equipped with safety devices against overheating, short circuits and overvoltages. An effective solution to eliminate single-point control problems.
Régulateur de tension LT1963
AOP LME49710NA
AOP LME49710NA
Two low-noise LME49710NA operational amplifiers complete the array with optimized operating voltage and current for high fidelity use.
These operational amplifiers manage to pick up the signal with an extremely low distortion rate (0.00003%).
Note that these AOPs are interchangeable. So you can easily replace them to experiment with different treatments and refine the integration of this DAC into your channel.
Gold plated copper RCA
To inject a clean and clean analog signal into the rest of the chain, special care has been given to the RCA output. The latter is constructed of gold-plated copper for high conductivity guaranteeing an undegraded signal to the amplifier.
Fiches RCA Module DAC AK4497EQ
Velvet Sound filters and architecture
Module DAC compatible amanero
The Velvet Sound technology available natively in the AK4497EQ DAC embeds 6 distinct filters. (Super Slow Roll-off, Slow Roll-off Short Delay, Slow Roll-off, Low Dispertion, Short Delay Sharp Roll-off and Sharp Roll-Off.) These possibilities will help integrate this decoder into your audio installation with respect to other components' specificity.
This module has a dedicated slot which can receive a USB interface (Amanero) and thus benefit from DSD & I2S decoding capabilities
Not all USB interfaces support DSD. We recommend the model XMOS U208 CPLD USB-B to SPDIF I2S Interface 32bit/384kHz DSD512 which supports DSD.
You will need to use a straight 2x10 round pins connector to connect the USB interface.
Mounted screen and control board
Module DAC avec écran et interface 3 boutons
Ce module DAC est piloté par un panneau à trois bouton et un écran OLED épuré, sobre et lisible.
Ces derniers sont livrés déjà montés sur le module.Il ne manque donc que le boîtier, l'alimentation et un module USB (facultatif) pour le mettre en route..
control panel
TypeModule DAC
inputsCoaxial, Optical
USB (requires module)
ExitsRCA Stereo
chip DACAK4497EQ
regulatorsLT1963 + 2x LM2941CS-1A
Op AmpsLME49710NA
TransformerAC 2x16v, 9V, 9V
SamplingCoaxial: 192K 384K USB
24B 32B + DSD 2.8, 5.6, 11.2, 22.4MHz
Control cardProvided (three buttons)
Screenprovided
dac card Dimensions150 x 160 x 50 mm
Dimensions screen map39 x 113 x 26.7 mm
Spacers screen map90 x 27.5 mm
Interface Card Dimensions88 x 17.3 x 10 mm
Interface Board Spacers78 mm
USB interfaceNot included (available slot)
Power cable & transformernot supplied
FrameNot provided
InputI2S
5 reviews
Rectificatif sur avis précédant
J'ai finalement retiré les AOP Burson... Ceux d'origine sont très bien !
This review has been posted for DAC Module AKM AK4497EQ I2S SPDIF 32Bit / 384kHz LT1963 Regulator
Excellent !
Rien à redire, c'est vraiment très bon. Les micro détails ressortent très bien, la diaphonie est excellente et la dynamique époustouflante ! Il mérite un très bon ampli et de très bonnes enceintes pour lui rendre honneur. Meilleur que des DAC du commerce coutant + de 10 fois son prix.
Excellent DAC, j'ai changé les AOP par des Burson et ajouté une interface USB Amanero. J'utilise Ap-Linux comme source.
Le firmware de l'Amanero doit être flashé sous windows pour éviter des bruits parasites avec les DSD et en PCM 48kHz. La configuration CPLD_for_1080 / 2003be_71A fonctionne bien.
Excellent DAC
Excellent rapport qualité prix, très musical, en changeant les AOP par des Burson V6 Classic, c’est sublime.
Je suis globalement satisfait par l'achat. 2 bémols néanmoins. Le DAC est livré sans notice et sans boite d'emballage. Seule la protection pour l'envoi est tout juste correct ... Surtout, les soudures entre la commande 3 boutons et l'écran de contrôle sont très fragiles : elles ont tenu à peine 2h ! j'ai du ressouder ! Dommage pour le prix et la qualité du DAC ...
This DAC will allow you to link all your digital players to your channel via the digital interface or via a USB module to submit an analog signal...
