2x TDA1305T CS8412 USB SPDIF 16bit 48kHz
This simple DAC module is based on the use of two TDA1305T digital to analog conversion chips, one per channel, supporting PCM audio streams up to 16bit 48kHz. These are associated with a CS8412 SPDIF interface and a 12MHz MCO clock to reduce jitter considerably.
For the connectivity, the module offers coaxial, optical Toslink and USB-B as inputs. The output is either stereo RCA or 3.5mm jack.
Connecting the USB automatically disables the SPDIF inputs.
The simultaneous connection of the optical and coaxial inputs can generate noise.
Product type | DAC Board |
DAC Chips | 2x TDA1305T |
Inputs | 1x USB-B 1x Optical Toslink 1x Coaxial |
Outputs | 1x Stereo RCA 1x Jack 3.5mm |
Supported sampling rates | PCM up to 16bit 48kHz |
SPDIF Interface | CS8412 |
Dimensions | 139 x 109mm |
Input | USB |
Input | Optical |
Input | SPDIF |
Output | Jack 3.5mm |
Output | RCA |
DAC / ADC Chip | TDA1305T |
Max sampling rate | 48kHz |
