DAC Board CS4398 CS8416 24bit 192kHz
This DAC module will allow you to enjoy a digital to analog conversion at a low price and ideal for integration in a DIY project. Its conversion stage is based on a CS4398 DAC chip, supporting PCM audio streams up to 24bit 192kHz. SPDIF reception is provided by a CS8416 chip. The module also integrates a NE5532P AOP on its output stage, mounted on DIP8 and therefore easily interchangeable.
Reference : 16528
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
DAC Board
Module DAC CS4398 CS8416 24bit 192kHz
For the connectic, we find in input Toslink optical and coaxial. For the outputs, the module provides stereo RCA and a second analog output on XH2.54mm 3 pins connector.
Product typeDAC Board
DAC ChipCS4398
SPDIF ReceiverCS8416
Inputs1x Optical Toslink
1x Coaxial
Outputs1x Stereo RCA
1x XH2.54mm 3 pins
Supported sampling ratesPCM up to 24bit 192kHz
SNR> 120dB
Dynamic range> 120dB
THD+N-107dB
Supply voltageDouble 12VAC
Dimensions82 x 50 x 22mm
Weight40g
OutputXH 2.54mm
DAC / ADC ChipCS4398
Max sampling rate192kHz
This DAC module will allow you to enjoy a digital to analog conversion at a low price and ideal for integration in a DIY project. Its conversion...
