JustBoom DAC HAT DAC PCM5122 for Raspberry Pi 3 / Pi 2 / A+ / B+
Reference : 11602
37,90 €tax incl.
31,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
The DAC JustBoom Raspberry Pi DAC HAT is designed to be simple to install and use. This product is also well suited for beginners and seasoned professionals as it requires no soldering.
just boom DAC HAT PCM 5122
Simply connect your HAT DAC to an audio amplifier to be operational quickly, enjoying high-quality, high-quality audio playback. We also include an optional IR receiver to allow remote operation of your Raspberry Pi.
This DAC includes a 32MB / 384kHz PCM5122 chipset with a Hardware volume and a 138mW headphone amplifier. The Just Boom DAC HAT uses the I2S interface for its audio input, which reduces the CPU load on the Raspberry Pi compared to USB solutions.
It is directly powered from the PiP or Pi3 GPIO connector, so no additional cables or power supplies are required. All GPIO pins of the Raspberry Pi are always accessible on the DAC HAT to facilitate the customization of your project.
You can add additional sensors, buttons, LEDs, rotary encoders or whatever your heart desires.
The DAC JustBoom Raspberry Pi DAC HAT can be used in many applications:
  • Streaming High Definition Audio Player
  • Multi-room audio player
  • Multimedia center / decoder lounge entertainment system
  • Shop / lift / music room
  • High quality audio player with local storage
  • High Definition audio player with amplified headphone output
Find here all JustBoom editing guides:
Get Started JustBoom
JustBoom DAC HAT Bundle PCM5122
Features:/ Strong>
  • Resolution DAC: 32bit 384KHZ
  • Includes both a DAC amplifier and a headphone
  • 3.5 mm jack outputs amplified headphones and RCA output
  • Compatibility Plug and Play
  • Hardware and software volume control of your Raspberry Pi
  • No welding required
  • Compatible with Raspberry Pi A +, B +, Pi 2, Pi3
  • Infrared soldering receiver included in package
  • Compatible with the JustBoom amp easily stacking on the HAT DAC (offers additional outputs)
  • All GPIO pins of the Raspberry Pi always accessible via a 40pin extension header
  • DAC fully compatible HAT Raspberry Pi
  • Full support for Raspbian drivers
  • Compatible with OSMC / RuneAudio / Volumio / Moode / PiCorePlayer / PiMusicBox / OpenELEC and others
Technical informations :
  • Chips: TI PCM5122 DAC 32 bits 384kHZ
  • Headphone Amplifier TPA6133A2 138mW
  • Fully integrated hardware volume mixing via ALSA compatible "alsamixer"
  • Built-in EEPROM: Automatic configuration of the Raspberry Pi driver (depending on the distribution)
  • IR receiver included in Vishay TSOP4838 package (solder if necessary)
  • 112dB signal-to-noise ratio (SNR) and -93dB total harmonic distortion (THD + N to -1dB)
  • Advanced anti-static (ESD) protection on headphone and RCA outputs
  • Ultra Low Voltage Voltage Regulator LDO
Dimensions and weight:
  • Dimensions: 13 x 7.5 x 2.5 cm
  • Weight: 65gr
Installation guide :JustBoom HAT DAC
JustBoom Test - How to turn a Raspberry nano computer into a multiroom audio system
ON-mag logo
Schematic diagram and example of JustBoom products -
InputI2S
Channel2 (Stereo)
2 reviews
eric
testé avec picoreplayer / super resultat.
le DAC est dans la liste du logiciel / tres facile a mettre en oeuvre.
c'est mon premier DAC avec raspberry et je suis vraiment etonné du son produit.
sinon livraison +++
bref fortement conseillé (mais par un newbee / héhé)
This review has been posted for JustBoom DAC HAT DAC PCM5122 for Raspberry Pi 3 / Pi 2 / A+ / B+
PAscal
Arrivé rapidement, fonctionne parfaitement, bien emballé.
Et surtout, testé avec volumio, runaudio, picoreplayer.
L'un des plus compatible.
Je recommande le dac, et le site.
