ST4000 DAC ES9018K2M HDMI I2S TCXO 32Bit / 384kHz for Raspberry Pi
ST4000 DAC ES9018K2M HDMI I2S TCXO 32Bit / 384kHz DSD256 for Raspberry Pi
Reduced price!
Limited special offer
109,00 €tax incl.
98,10 €tax incl.
81,75 € tax excl.
Shipping date: 26-03-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Discover this exceptional DAC ST4000, equipped with the ESS Saber ES9018K2M chip that can decode the signals up to 32Bit / 384kHz. The unique feature of this DAC is its ability to be driven by Raspberry Pi without driver,directly via the HDMI port.
This digital-to-analog converter featuring unprecedented features is ideal for transforming your Raspberry Pi 3 / Pi 2 into a true high-definition file player.
Equipped with the high-end SABER ES9018K2M chip, connectorsgold plated and a TCXO 100MHz clock, this DAC will offer you musical sound, dynamic and rich in micro details.
Intended for the many open source software solutions dedicated to audio playback, it allows a simpler implementation than ever for an incomparable result and very high performance.
The ideal power supply for this ES9018K2M DAC is available as accessories: Power adapter Power supply 100-240V to 5.1V 4A.
WARNING !! :According to the distribution based on Linux Raspian kernel, the output HDMi I2s is limited in bitrate to 16bit 48khz.
  • DAC ESS Saber:ES9018K2M
  • AOP stereo analog output chip: Burr Brown OPA 2604AU
  • THD + N: 120dB
  • Signal to noise ratio: 127dB
  • Output Level: 2V RMS
  • Ultra low precision TCXO 100MHz ultra low jitter clock
  • Inputs: HDMI / GPIO Raspberry Pi
  • Outputs: High quality stereo RCA Plated Gold / HDMI Plated Gold / Mini Toslink Optical
  • DC input on 5.5 / 2.1 mm Jack for power supply
  • Compatibilities: Moode Audio / OSMC / Openelec / Rune Audio / PiCorePlayer (Driver RPI DAC to I2S) / Etc ...
  • Supported Audio Formats: LPCM 2Ch / Dolby Digital 2 to 5.1Ch / DTS 2 to 5.1Ch
  • 100% compatible with ALLO KALI in I2S mode
  • Receiver and transmitter HDMI conform to HDMI 1.4 / 2.0a standards
  • Deep Full HD Support 12 bit, Full 3D, HDR and 4K2K 60Hz 420 video
  • Support HDCP 1.4 conversion to HDCP 2.2
  • Support HDCP 2.2 conversion to HDCP 1.4
  • Supports Repeater and HDCP 1.4 / 2.2 compliant
Supported sampling rates:
  • HDMI: 32Bit / 384kHz
  • I2S: 24Bit / 192kHz
  • Optical SPDIF: 24Bit / 192kHz
Dimensions / Packaging:
  • Supplied in 5V / 4A: power supply available in accessories
  • Supplied with 8 screws and 4 spacers M2.5 used to fix it on the Raspberry Pi (HAT format), as well as the gold-plated HDMI offset
  • Mounting Hole Distance (HAT): 50x58mm
  • PCB Dimensions: 85x87mm
  • Weight: 76g
  • Color PCB: black
Jumper de liaison à modifier ES9018K2M HDMI
Schéma technique DAC
Channel2 channels (Stéréo)
Colissimo - TNT - SoColissimo
