WONDOM AA-AB41131 I2S DAC CS4334 Board 24bit 96kHz Headphone Amplifier SGM4809 87mW 32 Ohm
Sure I2S DAC CS4334 Board 24bit 96kHz Headphone Amplifier SGM4809 87mW 32 Ohm
Reference : 10059
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
This DAC module developed by Sure Electronics has been designed to fit your DIY type amplifier or headphone amp designs with the utmost ease.
It allows you to convert an I2S digital audio signal to analogue stereo via a Cirrus Logic CS4334 24bit 96kHz converter.
Theline outputs are doubled for ease and power is supplied via DC jack or screw terminal block.
The necessary wiring is supplied with the module.
Features:/ Strong>
  • DAC Cirrus Logic CS4334
  • Supported sampling rates: up to 24bit 96kHz
  • THD + N: -88dB
  • Dynamic range: 96dB
  • Filtered output stage (LPF)
  • LED status indicator
  • Lined line outputs: RCA or screw terminals
  • Amplified Output Jack 3.5mm
  • Amplifier SGM4809
  • Output power: 87mW at 32 Ohm, 158mW at 16 Ohm
  • Anti Pop / Click Protection
  • Caution: No volume adjustment
  • Operating Temperature Range: 0 to 50 ° C
  • Power Supply via Jack DC 5.5 / 2.1mm 12V (1A) or pads
InputI2S
OutputJack 3.5mm
DAC / ADC ChipCS4334
Max sampling rate96kHz
Channel2 (Stereo)
