This DAC module developed by Sure Electronics has been designed to fit your DIY type amplifier or headphone amp designs with the utmost ease.
It allows you to convert an I2S digital audio signal to analogue stereo via a Cirrus Logic CS4334 24bit 96kHz converter.
Theline outputs are doubled for ease and power is supplied via DC jack or screw terminal block.
The necessary wiring is supplied with the module.
Features:/ Strong>
Input | I2S |
Output | Jack 3.5mm |
Output | RCA |
DAC / ADC Chip | CS4334 |
Max sampling rate | 96kHz |
Channel | 2 (Stereo) |
