ALLO USBRIDGE Black Acrylic - Audio Media Player Squeezelite DietPi Roon Interface for USB DAC
ALLO USBRIDGE Black Acrylic - Audio Media player Squeezelite DietPi ROON interface for USB DAC
The ALLO USB Bridge is a streamer player with a USB Bridge card and SBC ALLO Sparky. It transforms your USB DAC into a Squeezelite or Roon network drive with the best USB output on the market, allowing you to attack a USB DAC with the highest quality digital audio transfer.
4.4 / 5
Reference : 12073
155,00 €tax incl.
129,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
Allo USBridge
USB interface
Allo USBridge
High quality USB interface
An ALLO SPARKY is not initially designed for high fidelity applications. Its voltage regulators and USB ports are noisy. The USB Allo USBridge interface lets you output a USB AUDIO Class 2 signal with no noise, great stability. Your DAC USB finally receives an ALLO SPARKY, the digital signal in its entirety, without jitter.
The Allo USBridge was therefore created to overcome all these problems. To do this, it uses two independent USB controllers on a proprietary clock, a chip that reformats the signal using high-quality NDK oscillators, powered by independent LDO controllers and high frequency filters. Thus, the harm distortionis attenuated to the maximum to perfectly restore your music.
The Allo USBridge is comparable to MicroRender Sound in its use, while carrying high-quality components.
The Allo USBridge comes with an Allo Sparky SBC (Single Board Computer), an eMMC 16Gb, a transparent acrylic case and the DietPi operating system, allowing you to mount a system that you can connect directly to your DAC. The USBridge does not need a driver, it is completely transparent with the software solution used.
DietPi Open Source Logo
Video test de Hans Beekuysen du ALLOBRIDGE
"le Allobridge est en tout point comparable aux meilleurs solutions du marché et notamment très proche du SOTM Sm200".
The Hans Beekhuysen Channel novembre 2017
Input1x GPIO for Allo Sparky
Output1x USB
Power supplyVia jack DC 5V 3A -5.5 / 2.5mm (AC power adapter included)
Package1x Allo USBridge + 1x Allo Sparky + 1x eMMC 16Go + 1x acrylique Black Case
Allo USBridge
Allo USBridge
Allo USBridge
Allo USBridge
Caution: This product contains only a USBridge interface, an SBC Sparky, an acrylic case and a DietPi OS. The SMSL AD18 and the DAC Audio-GD are not provided.
interface dietpi allo
Software management
System options
System performance data
O!MPD Interface
Roon Interface
OutputUSB
5 reviews
Overall great Service
Great product. Works as expected. Excellent service.
This review has been posted for ALLO USBRIDGE Black Acrylic - Audio Media Player Squeezelite DietPi Roon Interface for USB DAC
Superb sound...
Works very well with Roon and my AVM DAC/Amplifier. Acrylic case is a bad choice. Therefore I ordered the aluminum case for about 60 euro's extra. Should be available without the acrylic case!
Tiens ses promesses
Je me suis laissé tenter par cet appareil après avoir expérimenté des distributions Linux plus classiques en les allégeant moi même et en y installant un noyau temps réel aux petits oignons.
Dès le départ et avec l'alimentation fournie: le résultat était proche des mes Raspberry Pi3 et PC optimisés jusqu'à l'alimentation. Un peu en dessous mais très proche.
En remplaçant l'alimentation fournie par une alimentation plus stable (iFi iPower), j'ai eu un bond en naturel qui fait que mes anciens appareils vont pouvoir être recyclés sur une autre fonction que celle de maillon pour le transport USB.
Appareils USB employés lors des tests: DAC Chord 2Qute et Mojo, lecteur SqueezePlay sur les différentes plateformes testées (sur base de Debian personnalisées)
Acheteur heureux!
Excellent produit!
Livré très rapidement
opérationnel dès les branchements effectués
Je recommande à 100%
c'est de la bombe
je m'en sert pour alimenter mon dac audio GD en usb meilleure qualité de son qu'avec le digione en coax
The ALLO USB Bridge is a streamer player with a USB Bridge card and SBC ALLO Sparky. It transforms your USB DAC into a Squeezelite or Roon network...
