It's a nice product and good for a dac
This is original Amanero Combo384 module : Audiophonics is a certfied Amanero reseller.
USB to I2S DSD
This USB to high quality I2S interface module allows you to get an I2S output / DSD from a computer source.
Combined with a DAC working with I2S input it enables you to build a complete product for reading from digital streams from a USB source such as a Windows, Mac or Linux machine.
It uses an ARM Cortex M3 ATSAM3U processor and convert the signals using a CPLD XILINX XC2C64A model. These use two TCXO low phase noise clocks 24.5760 & 22.5792 MHz. The interface module can thus handle high sampling frequencies (up to 384kHz / DSD512) with a low jitter.
Another version of this module is available which has an additionnal S/PDIF interface.
Type | Digital interface |
Logic circuit | ARM® Cortex®-M3 ATSAM3U Xilinx® CPLD XC2C64A |
Clocks | 2x TCXO |
Input | USB-B |
Output | I2S |
Sampling rates | 44.1Khz 48Khz 96Khz 88.2 176.4 192Khz 352.8Khz 384kHz |
Output Format | I2S 32bit or DSD64, DSD128 - and Windows DSD256, Native DSD512 |
Clocks | 2 TCXO low phase noise (for a minimum jitter) |
OS Support | No drivers needed for Mac OS 10.6 + or Linux (Kernel compliant UAC) |
Microsoft systems | Drivers for support : KS / WASAPI / WDM / ASIO |
PCB dimensions | 30x69 mm |
Average votes 4.9 / 5 8 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Teus V.
Jean-Francois B.
Pierre R.
John B.
