HYPEX DLCP add-on set Input board Preamplifier with Control board
By buying this product you get 28 loyalty points
9656
285,00 €tax incl.
237,50 € tax excl.
The DLCP add-on set consists of an input module and a control interface.
It transforms your DLCP into a true digital preamplifier and connects to the DLCP with only two flat cables.
With this input module you can now increase the number of analog inputs up to 4 balanced stereo analog inputs.
Themodule has four digital inputs: USB, AES-EBU (XLR / RJ45), Coaxial S / PDIF and Toslink Optics.
heis also equipped with two digital outputs: AES-EBU (XLR / RJ45) and Coaxial S / PDIF.
It is possible to connect two DLCPs with a single input module switchable on the PCB.
The interface allows you to control volume, channel assignment, and input selection without the need for a USB connection.
It can be connected to the input module with a single RJ45 cable (max. 10 meters). This interface has an LCD display that displays the settings and contains an infrared receiver for an IR remote control.
Thethe IR control (not included) can control the volume, mute, input selection and turning on.
When two or more DLCPs are used, only one control interface is required.
Characteristics :
  • DLCP Input Module
  • Control Interface
  • Inputs: RCA, 4x XLR Symmetrical, XLR AES-EBU, RJ45, USB, Coaxial, Optical
  • Outputs: XLR AES-EBU, RJ45, Coaxial
Colissimo - TNT - SoColissimo
