XMOS U208 USB-B to I2S Interface 32bit/384kHz DSD256
XMOS U208 Interface USB-B vers SPDIF I2S 32bit/384kHz DSD256
Reference : 14723
39,90 €tax incl.
33,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
USB Interface XMOS U208
Here is a USB to I2S interface. It works in asynchronous mode with an XMOS U208 USB chip optimized for high fidelity audio applications.
The interface supports digital audio streams up to 32bit-384kHz sample rate as well as DSD streams up to DSD256 on its I2S output.
It can be powered directly via USB or with a separate 3.3V power supply thanks to an integrated ultra-low noise LDO regulator. Allowing the easy setup of a power supply with battery or adapt to a power supply module designed for Hi-Fi uses. The USB power supply is automatically shut when an external power supply is detected.
Example of use
The interface is ideal for all your DACS I2S modules. In the photo above, it is associated with a balanced I2S 32Bit ES9028 DAC module (not supplied with the module).
TypeUSB to I2S interface
InputUSB on USB-B connector
OutputsI2S on pellets
Dimensions30 x 70 mm
SpacersM3
Distances21 x 63 mm
OutputS/PDIF
OutputI2S
Max sampling rate384kHz
Max sampling rateDSD256
Interface chipXMOS XCore U208
USB to I2S
Perfetto al 1° colpo.
This review has been posted for XMOS U208 USB-B to I2S Interface 32bit/384kHz DSD256
