AUDIOPHONICS PSU S4-HP Linear Power supply Module DC Micrel29752
Audiophonics PSU S3 Linear Power supply Module DC LT1083
4.8 / 5
Reference : 10435
75,00 €tax incl.
62,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Audiophonics PSU HP-S4
Audiophonics power supply module PSU S4-HP has been designed to provide clean power for an amplifier or any continuous audio circuit.
This version has a 6.5mm pre-drilled aluminum plate to improve heat-dissipation capacity and allow the module to deliver greater power. Those pre-drilled holes make it easier to mount the module into a housing or a heatsink.
It is equipped with a potentiometer and a jumper to adjust the voltage from 5 to 24V from an AC voltage source whose value is between 5 and 20V AC respectively.
Rigorous design and quality components make the PSU S4 HP an excellent choice to power a digital amplifier or any other Low Voltage High Fidelity devices such as DAC, headphone amplifiers for enhanced audio performance. For this purpose, the module uses 2x 1N5408 and 4 x 2scz2545 fast switching diodes.
The voltage regulator is a Micrel 29752, a popular component for critical systems due to its extremely low dropout.
This power supply has an impressive capacity for filtering with no less than 10 Nichicon electrolytic capacitors 4700µF 35V (for a total of 47000μF available for filtering). A final output capacitor provides further enhancement for the PSU overall accuracy.
Diodes42SCZ2545
Capacitor10x Elna 5600µF 35V
6x MKT (for diodes).
1x OsCon 150µf (output filtering)
Voltage RegulatorMicrel 29752 7.5A
Discharge resistorIntegrated
Output VoltageAjustable by means of a potentiometer + jumper (Transformer must provide appropriate voltage)
Jumper On: Adjustable from 12 to 24V
Jumper Off: Adjustable from 5 to 12.5V
Output VoltageVariable 5 to 24V
Maximum output currentto 7.5A according to the heatsink
connectable Maximum Music Powerapproximately 150W
Dimensions130 x 60 x 37mm.
Spacings50mm, 120mm
Distances heatsinks bores50mm
Weight204g
Transformer voltage5 to 20V AC.
Exemple : 11 or 12V AC for a 12VDC Output, the transformer must be able to deliver a rectified voltage with a delta of 4 to 6V DC
InputPCB Connector
OutputPCB Connector
Output voltage (V)5.0
Output voltage (V)10.0
Output voltage (V)24.0
Output voltage (V)12.0
Output voltage (V)20.0
Output voltage (V)15.0
Output current (A)7.5
Input voltage (V)N/A
Power SupplyRegulated Linear Power Supply
6 reviews
très bonne alimentation
elle vient remplacer trois modules à base de LT 1084 avec un condo 4700 µf qui alimentait deux PC dédiés (serveur Roon et lecteur Roon sous fédora ccrma avec 35 et 10 W de tpd)
Pour à peine plus chère, la différence est bluffante.
Les basses sont plus tendues, les timbres et la dynamique sont à l'avenant, les détails ressortent mieux.
Meilleur silence de fond.
C'est clair que l'alimentation est la clef de la qualité audio.
This review has been posted for AUDIOPHONICS PSU S4-HP Linear Power supply Module DC Micrel29752
Qualité remarquable
Je l'utilise pour alimenter en 24V un ampli casque à lampes avec en amont une module SPMS calé sur 25.5V. Cela donne d'excellent résultats en terme de qualité sonore. Très satisfait.
alimentation linéaire
j'utilise cette alimentation pour alimenter un l streamer de réseau de haut performance (3DLAB.nanoplayer).en remplacement de l'alim d'origine (un vulgaire boitier 220v/9v, polluant à fond..!.
le résultat est saisissant , lors d'une écoute "audiophile". (j'ai une installation avec un ampli a tube 845, et des baffles en supravox, de conception maison.) . SUPER RESULTAT. bravo.
Utilisée pour alimenter une carte mère sous Daphile (CPU de 10w de TDP).
Dimensionner impérativement le radiateur en fonction de la consommation, stabilité parfaite du voltage de sortie. A l'écoute, très supérieure aux cartes avec régulateur LT1083, différence de prix importante mais justifiée.
Sound
So far this has proved be excellent, voltage once set is rock solid, although the load i have on it is well below its rating (maximum of 2amps) and at that it runs cool.
Fairly robust it has with stood a dead short on the output due to me using a faulty low voltage power socket. In dead short conditions the unit did get hot and then shut down, after removing the the short and letting it cool down it powered back up and is sound.
Pair with a good transformer and you have an excellent linear power supply, recommended.
