HIFIBERRY AMP100 Class D Amplifier and DAC Board for Raspberry Pi 2x100W 4 Ohm 24bit 192kHz
The HiFiBerry AMP100 combines both a DAC+ Pro digital to analog converter and a Class D amplifier capable of delivering 2x100W of power. This is combined with a Raspberry Pi (sold separately) to create a complete and efficient audio system. An additional DSP module (sold separately) can also be added to it, to take advantage of a digital signal processing capability. This module also enables the digital inputs and outputs of the AMP100.
Reference : 16530
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 24-04-2024.
Shipping from France
Billing in France
Technical support in France
HiFiBerry AMP100
HiFiBerry AMP100 Module Amplificateur Class D DAC pour Raspberry Pi 2x100W 4Ω 24bit 192kHz
The HiFiBerry AMP100 is powered by an external power supply (sold separately). It is also capable of powering the Raspberry Pi that will be associated with it.
The AMP100's digital inputs and outputs are only active when combined with the DSP module (sold separately).
The L/R outputs can't be bridged.
1Power connector
2Optical Toslink input (requires the DSP board)
3Optical Toslink output (requires the DSP board)
4Power supply connector on screw terminal block
5I2S DSP Output
6I2S DSP Output
7Right channel output
8Left channel output
9DSP board connector
10Power switch jumper(leave free if the power controller is not used)
11Gain setting (open = 24dB, close = 18dB)
Product typeAmplifier and DAC board
InputsGPIO
1x Optical Toslink (requires DSP board)
OutputsSpeaker output on screw terminals
Supported sampling ratesPCM up to 24bit 192kHz
Output power2x100W @ 4Ω
THD+N< 0.05%
Supply voltage12-30VDC
Dimensions120 x 180 x 40mm
Weight180g
InputGPIO
OutputScrew terminals
OutputOptical Toslink
The HiFiBerry AMP100 combines both a DAC+ Pro digital to analog converter and a Class D amplifier capable of delivering 2x100W of power. This is...
