HYPEX UCD700HG HxR Class D Power Amplifier Module 700W 4 Ohm
Hypex UCD700HG-HxR Amplifier board 700W
The Hypex UCD700HG-HxR module is a Class D power amplifier, capable of delivering 700W and which will be able to adapt to very varied options, up to high-fidelity audio systems, including for professional use.
Reference : 4123
219,00 €tax incl.
182,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Hypex UCD700HG-HxR
Module d'amplification de puissance Hypex UCS700
The Hypex UCD700HG-HxR module is a Class D power amplifier, capable of delivering 700W and which will be able to adapt to very varied systems, up to high-fidelity audio systems, including for professional use. The strong characteristics of this module are its flat response whatever the load, its almost frequency independent distortion and an extremely low EMI radiation rate.
Find in the tab "Download" of this page the complete technical sheet of the product.
The DC offset can be adjusted by turning the potentiometer marked "DC ADJ".
Caution, never turn the potentiometer marked "TTADJ".
Technical diagram
Performances graphs
Components
Capacitorsx10 Hypex For Audio 200µF 100V
RégulatorsHxR Hifh performances regulators
Amplifier typeClass D Power amplifier
Output power700W @ 4Ω, THD=1%
THD+N0.02% @ 20Hz < f < 20kHz, Pout < Po/2
0.005% @ 20Hz < f < 20kHz, Pout = 1W
Noise30µ
Frequency response10Hz - 50kHz @ +0/-3dB
Efficiency> 92%
Compatible caseCan be mounted in a 2U housing, even on the side
Recommanded power supply voltage+/- 90V
Dimensions130 x 79mm x 35.7mm
Fixing holes spacing122 x 71mm
Weight300g
InputNC
OutputPCB Connector
Channel1 (Mono)
Amplifier chipN/A
Power (W)700.0
The Hypex UCD700HG-HxR module is a Class D power amplifier, capable of delivering 700W and which will be able to adapt to very varied options, up...
