Hypex DLCP DSP 6-Channel Programmable Active Filter
Hypex DLCP DSP Filtre actif programmable 6 canaux
By buying this product you get 34 loyalty points
Reference : 7869
349,00 €tax incl.
290,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
This DSP module is a complete programmable solution for filtering and active correction of multi-channel loudspeakers.
Applications:
  • Digital Preamplifier
  • Professional Audio Systems
  • Studio Monitors
  • Electronics Audio High-End
Features:/ P>
  • Compact design
  • Controllable via PC (delivered software)
  • Sampling rate supported at input 192 kHz
  • Symmetrical inputs and outputs (analog and digital)
  • Discrete clock low jitter
  • Six Channel Active Filtering
  • User Configurable Filters
  • Firmware updates via USB
  • Clock circuit and separate data
  • Six configurable balanced analog outputs
  • High level outputs for direct interfacing with buffered NC400 / UcD ST / HG
  • Adjusting the input gain by trimmer
  • 9 regulators
  • IIR Filtering
  • Sampling rate CPU 96khz
  • Standby
  • Molex Microfit Output Connector
  • Connectors for external LEDs
Mechanical data:
  • 110 x 110 x 30 mm
  • Distance between fixing holes 103 x103 mm
  • 140 gr
https://www.audiophonics.fr/images2/7869/7869_HYPEX_DLCP_DSP_1.jpg
Datasheet Manufacturer
