MiniDSP BOX 2x4 Audio Processor USB 2 to 4 channels Asymmetric
MiniDSP BOX 2x4 Audio processor USB 2 to 4 channel Unbalanced
4.2 / 5
Reference : 8270
87,50 €tax excl.
Including 0,25 € for green tax
Available
Shipping date: 17-06-2019.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
This small DSP can both serve as an active multi-channel filter, processor, source mixer, and converter.
It has two analogue inputs and four analog outputs.
Combined with a plug-in for programming, it is possible to configure audio processing filters in real time from a PC.
Once the card is configured, the device operates autonomously and therefore does not require the use of a computer.
MiniDSP 2x4 User Manual
Introducing the MiniDSP 2x4
Specifications:
- 28 / 56bit DSP Engine
- 24 bit ADC / DAC resolution
- Sampling rate of 48 kHz
- Unbalanced inputs can be switched with a jumper between 0.9Vrms and 2Vrms
- Unbalanced outputs: Max 0.9Vrms can be changed to 2V (see page 6 of the PDF)
- Digital audio input / outputs via I2S
- Condensateurs Audiophile Nichicon
- Volume control by connecting a potentiometer to the 3-pin connector
- Jack DC 5.5 / 2.1 cable for DC power supply
- Connection standard: Asymmetrical </ Span>
Are delivered:/ Strong>
  • 1 x shielded USB cable
  • Guide
DOWNLOAD A FREE PLUG-IN FOR THE MINIDSP 2X4:
For a full use of the miniDSP, it is necessary to have a plug-in.
There are several plug-ins available for download .
When receiving the product, you will receive in your package the method to follow to download the plug-in of your choice free of charge.
<p align = "center">
https://www.audiophonics.fr/images2/8270/8270_miniDSP2x4_dsp_1.jpg
https://www.audiophonics.fr/images2/8270/8270_miniDSP2x4_dsp_2.jpg
https://www.audiophonics.fr/images2/8270/8270_miniDSP2x4_dsp_3.jpg
Colissimo - TNT - SoColissimo
5 reviews
La bi amplification active pas chère et parfaite !
Acheté par curiosité, juste pour voir si la bi-amp. active est si efficace que ça, et bien oui je dois reconnaître que c'est bluffant !
Je n'ai pas ressenti cet effet bouchon décrit par un précédent acheteur, peut être un mauvais paramétrage, car il est vrai qu'il faut être très attentif pour la mise en oeuvre et avoir du temps devant soit, mais le résultat est là c'est excellent !
This review has been posted for MiniDSP BOX 2x4 Audio Processor USB 2 to 4 channels Asymmetric
très bon produit
Très bon produit, je l'utilise en audio embarqué, il est largement meilleur que les processeurs des autoradio "full actif", seul point négatif, c'est du 2 voies
Cependant, avec les autoradios avec au moins 2 paire de sortie RCA, l'autoradio peut très bien se charger de filtrer le subwoofer, et le miniDSP se charge de tout le reste.
la commande de gain n'est pas vraiment un souci
 (3)
Démarrer le filtrage actif à prix démoniaque
Bonjour,
Mon parcours : filtrage actif analogique maison (1990), Behringer DCX2496 "tweaké" puis MiniDSP 2x4 et 2x8 (avec module S/PDIF).
Tout d'abord je lis ci-dessous "bi-amplification active". Cette petite boîte propose bien plus que ça : le FILTRAGE actif et la correction EQ paramétrique. Au passage, je n'ai jamais écouté l'intérêt de la bi-amplification...
Ensuite, pour faire simple, ce que propose MiniDSP est au meilleur rapport qualité/prix du marché. J'ai installé un 2x8 sur mon système principal et c'est génial car tout-en-un : DAC, EQ et filtrage. Un DSP quoi !
J'installe ce 2x4 chez les copains pour des systèmes HTPC en 2.1, avec le plug-in (gratuit) "2 way Advanced 21" qui, comme son nom l'indique, permet de sommer deux canaux en un seul pour filtrer un sub. Plug-in (logiciel) des plus ergonomiques.
Des défauts ? Bien sûr ! Le niveau de sortie est effectivement relativement faible (changer les cavaliers sur le PCB), le potentiomètre de volume n'est pas présent (mais on peut l'ajouter en bricolant) et c'est de l'analogique, donc avec une double conversion E/S. Cela dit, cela reste transparent derrière un HTPC de bonne facture. Par exemple avec une ASRock.QC5000-ITXPH.
Cerise sur le gâteau, cette boîte s'alimente de 5 à 24V, donc via l'USB et/ou alim externe. Les fanas de la sono embarquée peuvent ainsi l'envisager dans leur joujou à 4 roues.
Pour terminer, cette version box est vendue à prix très raisonnable par Audiophonics surtout, en ce mois d'avril 2015, considérant la chute de l'Euro face au Dollar...
Génial !
J'ai acheté ce minidsp afin de tenter le passage à la bi-amplification active sans que ça me coute un oeil. J'utilise le mini-dsp comme filtre actif, égaliseur numérique 2x31 bandes et dac. Je l'accompagne d'un PC dédié et d'un DAC sympa en entrée (inutile de faire de la pub, ce n'est pas le sujet...), de 2 bons petits amplis tripath (4x10w, potars bypassé) en sortie et de deux enceintes 2 voies (filtres retirés, borniers changés)...
Le changement est simplement hallucinant ! Le coup du voile qu'on retire : c'est vrai !
J'ai rebranché mon gros ampli à tubes au bout de 15 jours pour voir... La messe est dite ! Le "gros à tube" part à la vente.
Attention, cet objet rend addicte à l'amplification active ! Idéal pour y mettre un pied sans se ruiner.
Je vous conseille de lui adjoindre une petite alimentation externe qui améliore encore la qualité. Il est nécessaire de pouvoir pratiquer des mesures afin de connaitre la courbe à appliquer dans l'égaliseur. Pas facile à l'oreille... Le seul reproche concerne les conversions successives nécessaires. Les éviter doit obligatoirement permettre d'améliorer encore la qualité de ce jouet fantastique. Du coup, je commence à regarder du côté du Nanodigi...
PS : Je ne ressens pas d'effet "bouchon". Par contre, je peux écouter plus fort qu'avant !
Comment dire...
Pour commencer, merci à audiophonics pour leur expédition très rapide et leur sérieux. Merci pour votre prise en charge! Ca c'est le bon côté...
Ensuite, après un après midi d'essais, en bi-amplification active, résultat très décevant! Tout d'abord, penser à changer le niveau d'entré de 0,9 à 2v! Et oui, il faut ouvrir le boîtier! Sinon pas de gain! Malgré ce changement, les niveaux de sortis reste très faible! Potentiomètre à plus de midi. Je précise, je possède des haut parleurs à haut rendement.
Cet appareil agit comme un bouchon!
A fuir absolument!
