MiniDSP OpenDRC-DA Room correction DSP DAC XLR Out
MiniDSP OpenDRC-DA8 Room correction DSP 32bit SPDIF
Reference : 10332
469,00 €tax incl.
390,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
The OpenDRC audio processors are designed for acoustic correction.
Powered by an Analog Devices DSP Sharp ADSP21369 32bit 333MHz, the OpenDRC-DA easily handles complex audio filtering treatments like room correction, FIR cross-filtering, reverb ...
Flexibility, high performance and low cost are the obvious features of the OpenDRC series.
The OpenDRC-DA (DA for Digital Audio DAC) supports the most common stereo digital audio formats via (AES-EBU, SPDIF and Toslink) to match your existing equipment.
So here is a device acting as a DAC 24bit 192Khz (SABER ES9023) and capable of advanced parametric corrections without loss of information.
The IR (remote) function and the rotary encoder will allow you to select your source without the need for a PC.
To establish the acoustic correction curves FIR and IIR it will be necessary one of the following software and a micro USB UMIK 1 sold separately:
http://www.roomeqwizard.com/(free).room eq wyzard
http://www.audiovero.de/en/acouratedrc.php paying.
Micro USB UMIK-1 review 8269.(sold separately).
This product is compatible with our remote control:
fiche 10901.
NOTE :
A version with digital inputs and outputs exists:
Mini DSP OpenDRC-DI sheet 9670.
A version with analog inputs and outputs exists:
Mini DSPOpenDRC-AN fiche 10595.
A version with 8 analog outputs for active filtering exists:
Mini DSP OpenDRC-DA8 file 10332.
Mini DSP Open DRC DA
Main Features :
  • DAC with Digital Correction via digital parametric equalization with FIR and IIR filtering.
  • CHIP DAC: SABER ES9023.
  • Compatible with Windows and Mac OS. (requires Adobe Air and Microsoft network).
Specifications:
  • Internal resolution 32bit.
  • FIR parametric filtering capacity on mono signal: 12228 taps @ 48Khz, 6144 taps @ 96khz.
  • FIR parametric filtering capacity on stereo signal: 6144 taps @ 48Khz.
  • Upsampling internal ASRC type (20 ~ 216Khz).
Inputs and outputs:
  • Digital Inputs: S / PDIF, Toslink Optics, XLR AES-EBU.
  • Analog Outputs: XLR Plated Gold.
  • USB-B 2.0 port for PC connection.
Dimensions and weight:
  • Dimensions:200x180x52mm.
  • Weight 2.2kg.
Package:
  • 1x OpenDRC-DA.
  • 1x USB cable Type B.
  • 1x Toslink Optical Cable.
  • 1x Power supply 5V DC 600mA.
  • 1x User's Guide.
[Img-13620-left-thickbox_default]
[Img-18911-left-thickbox_default]
[Img-18916-left-thickbox_default]
2 reviews
Très bon produit
Je connaissais le minidsp tout numérique en étant satisfait.
Je souhaitai un produit capable de remplacer les selfs et condensateurs nécessaires pour corriger la courbe de réponse d'un large bande et assurer la conversion NA.
Ce produit répond à mon besoin avec une belle transparence pour un coût raisonnable.
La sortie symétrique oblige néanmoins a utiliser un transfo (JENSEN) pour dé-symétriser afin d'utiliser un ampli à entrée asymétrique.
La doc du constructeur manque un peu de clarté sur le raccordement du point froid de la XLR.
This review has been posted for MiniDSP OpenDRC-DA Room correction DSP DAC XLR Out
magique
Tout d'abord, merci Audiophonics de proposer ces produits Mini-DSP. Livraison impécable.
Ce produit est magique pour tout audiophile. Pour un prix sommes toute raisonnable, il offre tout le nécessaire pour faire un système multi-amplification, sans filtres passifs, avec équaliser, cross-over et surtout, des FIR pour soit ne pas perturber la phase, soit faire de la room correction. Qualité du signal irréprochable, grande facilité d(utilisation, performance. C'est tout simplement un produit magique.
 (3)
