Significantly improved the quality of base in my speakers..
Electrolytic Capacitor 100V 100µF 5%
Jantzen Audio EleCap electrolytic capacitors are non-polarized aluminum capacitors using etched or "raw" foil. With a tolerance of ±5%, they are more accurate than most other standard electrolytic capacitors, often with a tolerance of ±10%. Both affordable and versatile, they are an excellent choice especially for bass channels or for integration into a crossover with limited space.
Product type | Electrolytic capacitor |
Rated voltage | 100VDC 35VAC |
Capacitance | 100µF |
Tolerance | ±5% |
Operating temperature range | -40°C / +85°C |
Leakage current | < 0.003CRUR (µA) |
Dissipation factor | < 0.1 @ 1kHz |
Signal direction | Non polarized (bi-polar capacitor) |
ESR max. | 0.16Ω |
Dimensions | 16x34mm |
Weight | 9g |
Tolerance (%) | 5.0 |
Capacitor capacitance | 100 |
Rated voltage (V) | 100.0 |
Capacitor type | Electrolytic capacitor |
Capacitor format | Axial |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
jevgenijs S.
killian D.
