Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Stephane G.
Incroyable !!
Je possède depuis une vingtaine d’années du Naim Audio (NAC 282 / HICAP / NAP 250.2) couplé à des ATC SCM 50 Passives.
Très...
Attention fragile
La conception est fragile et le conditionnement très sommaire : certaines des vis sont coincées dans la banane.
Egalement,...
Yves F.
Marvelous DAC
Ma configuration : Denon PMA 3000NE, streamer dmp a6 master edition gen 2 + dac holo cyan 2 (connection en USB : câble Black...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 2799
    Metal foil coils are physically the best designed. The output quality is constant up to 100kHz and unwanted capacitive loads are very low. The stability of the coil is also remarkable: thanks to the large contact area between the winding and the polypropylene insulator, vibrations are eliminated.
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 2803
    In Stock
    31,90 € 26,58 €Ex.
    In Stock
  • Ref : 2804
    In Stock
    33,90 € 28,25 €Ex.
    In Stock
  • Ref : 2805
    In Stock
    36,90 € 30,75 €Ex.
    In Stock
  • Ref : 2806
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 2807
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 2808
    In Stock
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 2809
    In Stock
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 2810
    In Stock
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 2812
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 2813
    In Stock
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 2814
    In Stock
    89,90 € 74,92 €Ex.
    In Stock
  • Ref : 2811
    In Stock
    64,90 € 54,08 €Ex.
    In Stock
  • Ref : 2815
    In Stock
    99,90 € 83,25 €Ex.
    In Stock
  • Ref : 2816
    In Stock
    109,90 € 91,58 €Ex.
    In Stock
  • Ref : 2818
    In Stock
    119,90 € 99,92 €Ex.
    In Stock
  • Ref : 2819
    In Stock
    129,90 € 108,25 €Ex.
    In Stock
  • Ref : 2820
    In Stock
    139,90 € 116,58 €Ex.
    In Stock
  • Ref : 2821
    149,90 € 124,92 €Ex.
    In Stock
  • Ref : 2822
    169,90 € 141,58 €Ex.
    In Stock
  • Ref : 2823
    194,90 € 162,42 €Ex.
    In Stock
  • 17,90 € 14,92 €Ex.
    In Stock
  • Ref : 11994
    In Stock
    18,90 € 15,75 €Ex.
    In Stock
  • Ref : 11995
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 11996
    In Stock
    20,90 € 17,42 €Ex.
    In Stock
  • Ref : 11997
    In Stock
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 11998
    In Stock
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 11999
    In Stock
    22,90 € 19,08 €Ex.
    In Stock
  • Ref : 12286
    In Stock
    25,90 € 21,58 €Ex.
    In Stock
  • Ref : 12000
    In Stock
    27,90 € 23,25 €Ex.
    In Stock
  • Ref : 12001
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 11980
    In Stock
    31,90 € 26,58 €Ex.
    In Stock
  • Ref : 12002
    In Stock
    33,90 € 28,25 €Ex.
    In Stock
  • Ref : 12003
    In Stock
    36,90 € 30,75 €Ex.
    In Stock
  • Ref : 12005
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 12006
    In Stock
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 12007
    In Stock
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 12004
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 12009
    In Stock
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 12010
    In Stock
    64,90 € 54,08 €Ex.
    In Stock
