LINDY Ethernet RJ45 Cable Cat 8.1 S/FTP LSZH Gold Plated 1m
The RJ45 Ethernet cable takes advantage of the latest Cat 8.1 standard to support bandwidth up to 2000MHz. The cable has an S/FTP structure, where the twisted pairs are shielded with an overall braided shield as well as an aluminum foil shield for each pair.
Reference : 14368
15,90 €tax incl.
13,25 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Lindy Ethernet Cable
RJ45 Cat 8.1 S/FTP LSZH Gold Plated 1m
Lindy Câble Ethernet RJ45 Cat 8.1 S/FTP LSZH Plaqué Or 1m
The RJ45 Ethernet cable takes advantage of the latest Cat 8.1 standard to support bandwidth up to 2000MHz. The cable has an S/FTP structure, where the twisted pairs are shielded with an overall braided shield as well as an aluminum foil shield for each pair. The connector contacts are made of gold-plated copper to ensure very good conductivity and resistance to oxidation, while complying with Ethernet standards up to 40GBase-T. The connector also has a hook-and-loop protection that locks the cable once connected and prevents it from being pulled out. The cable is manufactured and tested according to ISO/IEC 11801 specification.
Product typeEthernet cable
Connectors2x male RJ45
Length1m
Ethernet standardCat 8.1
Cable diameterØ7.5mm
Cable sheath diameterLSZH
Cable conductors materialCopper
Cable conductors section0.205mm² (24AWG)
Cable shieldingAluminium foil + braid
Connector contacts materialCopper
Connector contact platingGold
Connector platingNickel
Connector body materialPolycarbonate
Connector dimensions12 x 38.5 x 17mm
Supported bandwidth2000MHz
Nominal attenuation24dB/30m @ 2000MHz
Minimum radius of curvature60mm (2.36")
Operating temperature-10°C - 60°C (14°F - 140°F)
CertificationRoHS, REACH, UL
ColorGray
Length (m)1.0
ShieldingYes
Section (mm²)0.205
ConnectorRJ45
3 reviews
bon cable un peu rigide
installé entre les 2 elements d’une freebox. Effet imédiat par rapport àun câble standard. Câble un peu rigide.
This review has been posted for LINDY Ethernet RJ45 Cable Cat 8.1 S/FTP LSZH Gold Plated 1m
Good and afordable
Just a normal Ethernet wide cable with good enough connectors
I have some cables from this brand and all works perfect under a small price, great quality
Gain en qualité et vitesse
Après avoir remplacé mes câbles cat 5e par ces câbles, j'ai gagné sur mon réseau interne presque 10Mbps grâce à la propreté du signal. Le câble est plus gros que du câble ordinaire, il est aussi plus rigide mais les connecteur rj45 sont de bonne qualité et ne bouge plus une fois enfichés. Je recommande (j'ai mis entre boitier fibre et ma box puis de ma box vers du cpl...)
The RJ45 Ethernet cable takes advantage of the latest Cat 8.1 standard to support bandwidth up to 2000MHz. The cable has an S/FTP structure, where...
