PANGEA PREMIER SE Ethernet Cable RJ45 Cat7 Silver Plated Cardas Copper Triple Shielding 1.5m
If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver their full potential. With its First Ethernet SE, Pangea offers cables using top-of-the-range materials and a careful design to ensure excellent performance.
Reference : 13716
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
Pangea Premier SE
Pangea Premier SE Câble Ethernet RJ45 Triple Blindage Cuivre Cardas Plaquage Argent 0.6m
If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver their full potential. With its Premier SE Ethernet, Pangea offers cables using top-of-the-range materials and a careful design to ensure excellent performance.
Cardas Copper & Silver Plating
The Pangea Premier SE Ethernet integrates 26AWG (0.129mm²) copper cardas conductors with silver plating to ensure maximum conductivity. Cardas Copper, developed by George Cardas, has an exceptional quality. The latter is mined in Arizona and then sent to a New England factory where it is very slowly transformed into conductors via a long process to maximize its purity. The conductors are then delivered to a second factory in order to apply the Silver plating.
PE Insulation & Triple Shielding
Always with performance in mind, the cable is covered with a PE sheath. In addition, each conductor is individually shielded, a requirement for Cat7 Ethernet standard and triple shielding is then added to minimize the negative impact of EMI / RFI interference.
Product typeRJ45 Ethernet Cable
Connectors2x RJ45
Length1.5m
Ethernet categoryCat7
Conductors materialCardas Copper
Conductors platingSilver
Conductors section0.129mm² (26AWG)
InsulationPE
ShieldingIndividual shielding of each conductor + Triple shielding
Connectors platingGold
Cable colorBlack and Gray
Length (m)1.5
ShieldingYes
Section (mm²)0.129
ConnectorRJ45
Aération et silence
Dès la pose du câble, le son m'est apparu bien plus calme (moins de perturbation) se traduisant par de meilleurs silences, son moins agressif. Un très bon câble pour l'audio
This review has been posted for PANGEA PREMIER SE Ethernet Cable RJ45 Cat7 Silver Plated Cardas Copper Triple Shielding 1.5m
If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver...
