Aluminium Power connector IEC OYAIDE Ø20mm
Aluminium Power connector IEC / Schuko Ø 20mm
Robust and elegant, this Aluminium screw-on shell is compatible with OYAIDE IEC connectors. It was machined from the mass and then anodized. The finishes are impeccable (chamfers, threads, etc.).
Reference : 9488
17,90 €tax incl.
14,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
Aluminium shell
For ⌀20mm IEC Oyaide Connector
Coque Aluminium pour connecteur IEC Oyaide
This shell is compatible with Oyaide IEC connectors from the Oyaide C-0XX range:
MaterialAnodised Aluminium
ColorSilver
CompatibilityOyaide IEC C-0XX Range
Acceptable cable diameter20mm
Internal diameter38.5mm
External diameter45mm
Length56mm
Max cable diameter (mm)20.0
Top workmanship, affordable, highly recommanded
Very high quality aluminum, you got to hold it in your hand, before you believe / realize, the great afford there have been made and put in to the product.
The aluminum shell weights a lot more, than you can figure out from the picture !
This review has been posted for Aluminium Power connector IEC OYAIDE Ø20mm
Robust and elegant, this Aluminium screw-on shell is compatible with OYAIDE IEC connectors. It was machined from the mass and then anodized. The...
