SCHURTER Connector IEC C13 angled Ø8mm
Connecteur IEC C13 SCHURTER 4785 3x2.5mm² RoHS Coudé 90° Ø10mm
Reference : 9559
4,50 €tax incl.
3,75 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
Connector IEC C13 SCHURTER 4785 Elbow Ø8mm
IEC female plug, high quality, German made, RoHS certified.
Black nylon body with high heat resistance (up to 70 °).
The 3 conductors with a maximum cross-section of 2.5mm² are secured with 3 screws (2 poles + ground).
Compatible with cables up to 8mm in diameter.
Features:/ Strong>
  • Brass Contacts
  • Black Nylon Body
  • Fiche à Visser
  • Compatible with cables of Ø 8mm Max.
  • Current / Voltage: 250V / 10A
  • Temperature Range: -25 ° to 70 °
  • Body Length: 62mm
  • Dimensions: 87.5x28.7x21mm (L x W x H)
  • Approved: UL, CSA, VDE, BSI
  • RoHS Certified
https://www.audiophonics.fr/images2/5082/5082_IEC90D4785_1.jpg
https://www.audiophonics.fr/images2/5082/5082_IEC90D4785_2.jpg
Max cable diameter (mm)8.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C13
Rated current (A)10.0
accessoire très utile
Accessoire très pratique pour réaliser soi-même des cordons sur mesure (longueur, couleur câble,...)
Prix très correct .malgré la rareté de cet accessoire . Devrait être facilement disponible en d'autres normes .
This review has been posted for SCHURTER Connector IEC C13 angled Ø8mm
