the connection does not match the description. I had to get tired of connecting the 2.5 power cable. tired and assembled to connect the contact holds good.
IEC C13 Connector 3x 5mm² Ø16mm
This Elecaudio LI-24GB IEC C13 connector is ideal for creating quality power cords. It uses pure 24k gold plated copper contacts of 5mm², allowing a very good conductivity and therefore a perfectly transmitted signal. This connector can accommodate cables up to 16mm in diameter and is therefore suitable for both "classic" cables and HiFi cables with a larger diameter. The connector body is composed of PC 94V-0 and TPR. All screws on this connector are 304 stainless steel, preventing corrosion.
Connector type | IEC C13 |
Contact material | Pur Copper |
Placage | Or 24k |
Acceptable cable diameter | Ø16mm without sleeve / Ø13mm with sleeve |
Voltage / Current | 250V AC / 15A |
Dimensions | 108x22mm |
Weight | 42g |
304 stainless steel screw | Cruciforme |
Color | Black |
Max cable diameter (mm) | 16.0 |
Mounting type | To screw |
Connectic | Female |
Connector | IEC C13 |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Gold |
Rated current (A) | 15.0 |
Average votes 3.3 / 5 12 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Arturas J.
Jean Luc D.
Torsten S.
Pierre S.
Jean Michel e.
