ELECAUDIO PI-24GC Plug Power Supply IEC Crystal Gold 24K 3μ Ø16.5mm
ELECAUDIO PI-24GC Prise Secteur IEC Crystal Or 24K 3µ Ø16.5mm
6585
16,90 €tax incl.
14,08 € tax excl.
Available
Shipping date: 22-01-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
- We deliver this connector without marking, the small Elecaudio sticker visible on the pictures is not delivered -
The reference IEC plug PI-24GCis distinguished at first glance by its transparent nylon bodywith impeccable finishing and ideal proportions.
With a white screenprint in the brand's color, this chassis allows to receive the most sophisticated cables whose diameter often proves incompatible with the conventional outlets.
With herInsertion ring to limit diameter to 16.5mm , with a greenhouse flexible rubber cable the PI-24GC can easily accommodate cables with a large cross-section.
All metal parts, including the contact and ground poles, have benefited from a plating Gold 24k 3μ .
This plating over the entire surface of the contacts is more resistant and better conductor than the standard gold plating, and is thus more resistant.
The internal connection terminals also deserve attention: They are equipped with large fastening screws and therefore do not require any soldering, they are able to receive conductors of large diameter ( up to 16mm² section! ) of which they ensure a firm hold on a particularly wide and homogeneous contact surface.
Wewill appreciate the small diagram directly engraved within the catch, and provides information on the optimum length of cable to be stripped . Since you are told that nothing has been left to chance ...
Specifications:
  • IEC 3 plugs Screw-in contacts (BTR screws)
  • Plating:Or 24k 3μ
  • Maximum Driver Section:16mm² (4.5mm of Diameter)
  • Maximum Cable Diameter: 16.5mm
  • Voltage / Voltage Rating: 16A / 250V
  • Overall Length: 80mm
  • Diameter: 38mm
  • Weight: 60g
https://www.audiophonics.fr/images2/6585/6585_ELECAUDIOPI24GC_1.jpg
https://www.audiophonics.fr/images2/8095/8095_elecaudio_prisesecteur_PI-34GC_3.jpg
https://www.audiophonics.fr/images2/8095/8095_elecaudio_prisesecteur_PI-34GC_1.jpg
https://www.audiophonics.fr/images2/6585/6585_ELECAUDIOPI24GC_4.jpg
https://www.audiophonics.fr/images2/SCHEMA_PHASE.jpg
Cable schematics
MaterialLaiton
PlatingGold-plated
For cable diameters16.50
ConnectionScrew
ConnecticFemale
Section16
FormatEurope
ConnecteurC15
Colissimo - TNT - SoColissimo
Ravi de mon achat cette fiche est très bien, montage facile pour mes premiers cable secteur que j'ai monter, pour ce qui est du son comparé a mon cable secteur d'origine forcément c'est le jours et la nuit, avec un cable tornado, satisfait à ce jour ...
This review has been posted for ELECAUDIO PI-24GC Plug Power Supply IEC Crystal Gold 24K 3μ Ø16.5mm
