ELECAUDIO RI-24GB Hi-Fi IEC Power Plug 24k Gold Plated Ø15mm Black
ELECAUDIO RI-24GB Hi-Fi IEC Power Plug 24k Gold Plated Black Ø 16.5mm
Reference : 10454
24,90 €tax incl.
20,75 € tax excl.
Shipping from France
Billing in France
Technical support in France
These Hi-Fi power connectors where developed in France to be used with the most sophisticated power cables in the market.
The body with an exclusive and modern design was built with high pressure. His composition, 30% Fiber Glass, and 66% Nylon, can even support industrial environments, resistant to high temperatures, impacts and crushing.
We can even call these power connectors as a hybrid, an industrial quality adapted to a Hi-Fi use.
With his uniform 4mm body injection for effective vibration and resonance dampening you can use it in many ways.
Thanks to a twist grip clinch claw for cables diameters from 10mm to 15mm you can have a wide option of cable diameters to create the perfect Hi-Fi grade power cable.
All the connectors are screw Stainless steel for maximum strength.
The head of the connector also benefits of the alloy Fiberglass / Nylon for its dielectric and mechanical qualities. Contacts are copper alloy non-magnetic in one piece and machined from solid, which is applied on 24K gold plating.
Specifications:
  •    Body : 30% Glass Fiber & à 66% Nylon
  •    Screws: (Philips PH2)
  •    Plated: Or 24k
  •    Section Maximale des Conducteurs : 15mm² (4.5mm de Diamètre)
  •    Cable diameter : de 10mm à 15mm
  •    Tension/Voltage : 16A / 250V
  •    Total length: 95 mm
  •    Diameter: 42 mm
  •    Weight: 76g
Max cable diameter (mm)15.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Rated current (A)16.0
4 reviews
Good one!
Very good in Quality and handling. In the meantime i´ve build three powercables with the RI-24GB and would also use it for further Powercables :)
This review has been posted for ELECAUDIO RI-24GB Hi-Fi IEC Power Plug 24k Gold Plated Ø15mm Black
worth it´s price!
Todo correcto
Buen producto y envío muy rápido.
Idem que ma Shunko
Une bonne fiche solide et suffisamment spacieux pour faire quelques bouclages à l'intérieur.
Le tout présente une bonne rigidité.
Tout ce que je cherchais et pas de fioritures.
