Cette prise laisse tout passer sans rien modifié, ce qui est très rarement le cas.
Fabrication irréprochable.
Allez y les yeux fermés (mais les oreilles grandes ouvertes).
Power Connector IEC Pure Copper Gold Plated Ø20mm
The ETI Legato IEC connector benefits from a high-end construction based on the use of high quality components for optimal conductivity. For example, the connector contacts are made of high-purity 1100 Copper with an IACS rating of 102%. They are also gold plated, protecting them from oxidation while maintaining excellent conductivity. The body of the connector is made of machined 6061 Aluminum and is designed to limit the impact of EMI/RFI interference on the signal.
Product type | IEC Connector |
Contacts material | Copper 1100 series (IACS 102%) |
Contacts plating | Gold |
Body material | Aluminium 6061 series |
Max cable diameter | Ø20mm |
Color | Black |
Max cable diameter (mm) | 20.0 |
Mounting type | To screw |
Connectic | Female |
Connector | IEC C13 |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Gold |
Rated current (A) | N/A |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Michel M.
Jacques B.
Grzegorz B.
