Prise coudée de très bonne qualité, avec une FI48or sur un SP1100 ça marche très bien sur un R7.
Very high performance IEC power plug, ideal for assembling an Audiophile high-end power cable. This superb 90° angled plug and 270° rotatable connector offers the best fit for your Hi-Fi devices. In addition to its Gold-plated Copper contacts, the FI-12L also benefits from the proprietary FURUTECH Alpha α Anti-magnetism treatment.
The FI-12L model also takes advantage of the patented "Floating Field Damper System" technology which, according to the manufacturer, almost completely eliminates the creation of micro zones of magnetic and electrostatic turbulence inside the connector. Such perturbations may appear when current flows near conductive pieces of the structure in regular connectors (metal fixing screws, cable clamping elements, etc...) These “floating” micro force fields conflict with a much more powerful primary magnetic flux and may cause signal instability or distorsion. FURUTECH addresses this issue by connecting all the metal parts concerned to one another before connecting them to the ground to get rid of any undesired field.
Its body combines nylon and fiberglass composite material, incorporating carbon particles, which shows extreme resistance to shocks, electric arcs and high temperatures.
Compatible with cables between 6.6mm and 18mm diameter.
Type | Power plug IEC 15 |
Contacts | Pure Copper Gold plated |
Treatment | Anti-Magnetism FURUTECH Alpha α |
IEC connector rotation | 270° |
Case materials | Nylon & fiberglass |
Diameter supported | 6.6 - 18mm |
Voltage / intensity | 250V/16A 125V/16A |
Max cable diameter (mm) | 18.0 |
Mounting type | To screw |
Connectic | Female |
Connector | IEC C15 |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Gold |
Rated current (A) | 16.0 |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Philippe D.
Jamel I.
Laurent F.
