FURUTECH FI-50 NCF (R) Rhodium plated IEC Connector - Carbon Ø20mm
FURUTECH FI-50 NFC(R) Rhodium plated IEC Connector - Carbon Ø 20mm
This is the top-of-the-range IEC power connector for high-end audiophile power cables. This new version, christened NCF (Nano Crystal Formula), incorporates into the insulating body an active material generating negative ions that eliminate static discharges by converting them into thermal energy in the infrared spectrum.
4.5 / 5
By buying this product you get 132 loyalty points
Reference : 11107
449,00 €tax incl.
374,17 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Furutech combines this crystalline material with ceramic particles and carbon powder with Piezoelectric damping properties.
The combination with Nano Formula Crystal and ceramic piezo particles provides the ultimate mains plug, the longest-running Furutech know-how in this field.
NCF technology :
Incorporated into the new Furutech product range, NCF (Nano Crystal² Formula) is a special crystalline material with two "active" properties.
Firstly, it generates negative ions that eliminate static electricity, but it also converts thermal energy into far-infrared (LIR) at wavelengths ranging from (50 µm - 5 mm).
Furutech then combines this remarkable material with nanometric ceramic particles and carbon powder for their "Piezo Effect" (damping properties).
The resulting Nano Crystal² Formula (NCF) is the ultimate electrical and mechanical damping material - (Only available in Furutech products!).
Characteristics :
  • Conductors: Pure copper, Rhodium-plated "Furutech Alpha α"
  • Jumper system for ground disconnection
  • Insulation: Nylon / fiberglass
  • Housing: Nylon / fiberglass nano ceramic particles for vibration and resonance absorption
  • NCF: Antistatic nano-crystalline particles added to the carbon ceramic body
  • Non-magnetic multi-layer in stainless steel and carbon fiber
  • This connector adapts to an external cable diameter of 6.6mm up to 20m
  • 250V 10A.
Dimensions :
  • Total length: 80.3mm
  • Length of connector part: 44mm
  • Diameter: 34.5mm.
ColorWhite
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Rated current (A)10.0
4 reviews
No country of origin
Just came back from Japan Osaka and brought a pair of these connector but a bit disappointed on the packaging nothing is written Made in Japan.
Not on the boxes, not on the connectors even not on instruction manual.
But the products look very nice, well you have to trust with whom you buy!!!!
This review has been posted for FURUTECH FI-50 NCF (R) Rhodium plated IEC Connector - Carbon Ø20mm
Une bowté
Une tite bowté la prise mon coco
Top !
Associé au câble TCS31 de Furutech, le mariage est TOP (voir mon avis sur le TCS31) . Robuste, de grande qualité. Montage aisé.
Une référence !
Après plusieurs semaines d'utilisation (câble Oyaide EE FS2.6) sur mon DAC-préampli Nagra, avis extrêmement positif. Sonorité naturelle et neutre, gain par rapport à la FI-38 Gold en terme de neutralité, résolution, d'espace sonore et de rapidité. Pas de sonorité métallique, déséquilibrée vers l'aigu comme avec d'autres prises Rhodium furutech. Grave tendu et aigu précis, très fin. Aucune réserve, sauf le prix...
 (3)
This is the top-of-the-range IEC power connector for high-end audiophile power cables. This new version, christened NCF (Nano Crystal Formula),...
