NEOTECH NC-P303RH IEC Connector IEC Rhodium plated UP-OCC Ø24mm
NEOTECH NC-P303 Connecteur IEC UP-OCC plaqué or
Fiche secteur IEC femelle très haute performance, idéal pour la constitution d'un câble secteur Audiophile sans compromis. Les contacts sont en Cuivre pur (UP-OCC, 99,99999%) et plaqué Rhodium.
Reference : 10517
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 24-04-2024.
Shipping from France
Billing in France
Technical support in France
Neotech NC-P303RH
IEC Connector UP-OCC Rhodium Plated Ø24mm
Neotech NC-P303RH
  • Contacts : Cuivre Pur Plaqué Rhodium
  • Processus de cryogénisation propre à la marque NEOTECH
  • Compatible avec les Câbles de Diamètre compris entre 11 à 24mm
  • Réducteurs livrés
  • Diamètre des brins acceptable : 4.5mm
  • Longueur du Corps : 63mm
  • Longueur totale : 84mm
  • 250V/10A - 125V 15A
https://www.audiophonics.fr/img/p/7/4/4/0/7440.jpg
Max cable diameter (mm)25.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Rated current (A)15.0
6 reviews
Great metal work
I own a 3m "Wireworld Electra 7" power cable, which never completely convinced me. Now I changed the OEM plugs against the NEOTECH plugs. What shall I say, big improvement. Plastics are not the same level as Furutech, but metal work seems to do a great job.
This review has been posted for NEOTECH NC-P303RH IEC Connector IEC Rhodium plated UP-OCC Ø24mm
Best buy
Together with Neotech NC-312RH and used with a silver plated OCC- or pure OCC power cable, this is a best buy.
Look also at my review on NC-312RH
high quality
this is a wonderful IEC connector with top notch quality of materials OCC copper rodium plated.. it's also easy to connect with the power cable
High quality plug, but not top tier
High quality plug that gives good conditions for airy sound not limited by power. Used with Neotech NEP-3001 which is one of the best power cables on the market. Not as good design as e.g. Furutech FI-E38 (R) which provides better shielding and the smart cable clamps. Unless it was intended for a Neotech cable, I should’ve used the Furutech plug.
Requires cable sleeve clamps for all cables less than AWG 12ish.
Jak
Perfect connector. Exceeds Furutech Fi-28 R in my opinion.
Fiche secteur IEC femelle très haute performance, idéal pour la constitution d'un câble secteur Audiophile...
