Excellent connecteur, musical et précis, monté sur Elecaudio cs-361b vers un ampli Marantz... à renvoyer sur leboncoin des câbles secteur de grande marque.
Viborg VF501 IEC connector. Ideal to build / improve a cord high performance sector. This model will suit ambitious audio construction projects requiring excellent conductivity.
His pure copper conductor provides high conductivity. His isolan is nylon and fiberglass for increased durability and a greater electromagnetic neutrality.
Driver | Copper (99.9% pure) |
Insulating | Nylon / Fiberglass |
Connection | Set screw |
Supported cable diameter | 6mm-19mm |
Max. conductor diameter / cross-section | Ø 8mm / 50mm² |
Class | 15A / 10A 125V / 250V |
Dimensions | Height: 49mm Diameter: 33mm Total length: 72mm |
Max cable diameter (mm) | 19.0 |
Mounting type | To screw |
Connectic | Female |
Connector | IEC C15 |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | None |
Rated current (A) | 10.0 |
Rated current (A) | 15.0 |
Average votes 4.7 / 5 18 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Laurent C.
Paul G.
Jean Michel P.
Paul G.
