VIBORG VF502 IEC C15 Connector Pure Copper Ø20mm
VIBORG VF502 IEC C15 Connector Pure Copper Ø 20mm
This IEC C15 Viborg VE502G connector is ideal for creating quality power cables. It uses pure copper contacts to obtain a very good conductivity and therefore a cleaner transmitted signal.
4.5 / 5
Reference : 13167
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Viborg VF502
Connecteur IEC C15 Cuivre Pur Ø 20mm
Viborg VF502 Connecteur IEC C15 Cuivre Pur Ø 20mm
This IEC C15 Viborg VE502G connector is ideal for creating quality power cables. It uses pure copper contacts to obtain a very good conductivity and therefore a cleaner transmitted signal. In addition, this connector is able to accommodate cables up to 20mm in diameter and will therefore be suitable for both "classic" cables and HiFi cables with a larger diameter. Finally, the connector is covered with an Aluminium alloy body. This allows both to offer the connector a beautiful design but above all to limit EMI / RFI interference that could damage the signal and therefore audio reproduction.
Connector typeIEC C15
Contacts materialPure copper
Voltage / Current250V AC / 16A
Maximum accepted cable diameterØ 20mm
Max. conductor diameter / cross-section8mm / 50mm²
Dimensions81.5 x 40mm
ScrewHexa / Phillips
ColorSilver
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Rated current (A)16.0
4 reviews
Not exactly the copper one
I ordered a VF502S elsewhere moving from the 503S and the sound quality degraded. Swapping the contacts from the 503S into the 502 effectively gave me a super sounding 512S.
Audiophonics, please stock the 512S models. Sublime sound and cost
This review has been posted for VIBORG VF502 IEC C15 Connector Pure Copper Ø20mm
Wow Viborg
hello, le TOP!
Très bon rapport qualité prix
Très bonne finition.
Belle construction.
Améliore sensiblement l'écoute.
Connecteur assez lourd (environ 130 gr)
Viborg VF502
De la même trempe que la Shuko , se produit entièrement cuivre et de très belle facture , comme la Shko ,Cette l'IEC Viborg contribue à une meilleure définition du signal et améliore l'écoute .
Cordialement
This IEC C15 Viborg VE502G connector is ideal for creating quality power cables. It uses pure copper contacts to obtain a very good conductivity...
