VIBORG VF503S Connector IEC C15 Silver Plated Pure Copper Ø19mm
This IEC C15 Viborg VF503S high-end connector uses high quality materials to provide the best possible electrical conductivity. Thus, the contacts are made of pure Copper and benefit from a double plating of OFC Copper and Silver. The body is made of a particularly resistant polycarbonate, Bayer Makrolon 2805. The assembly is extremely simple with a screw system, so no soldering is required. The connector accepts cables with a diameter from Ø6mm to Ø19mm and conductors with a maximum diameter of Ø8mm.
4.8 / 5
Reference : 14578
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
Viborg VF503S
Viborg VF503S Connecteur IEC C15 Cuivre Pur Plaqué Argent Ø19mm
Product typeIEC Connector
Connector typeIEC C15
Cable external diameterØ6mm - Ø19mm
Max. conductor diameterØ8mm
Contacts materialPure Copper
Contacts platingOFC Copper
Silver
Body materialBayer Makrolon 2805
Connection typeTo screw
Dimensions55 x 40mm
Total length77mm
Voltage / Current250V / 10A
125V / 15A
Max cable diameter (mm)19.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Rated current (A)10.0
Rated current (A)15.0
4 reviews
Terrific connector
I had been using similar silver/copper IEC's as well as Rhodium ones and these Viborgs are little gems. I haven't heard such an immediate startling change before on changing such a small piece of the chain.
This review has been posted for VIBORG VF503S Connector IEC C15 Silver Plated Pure Copper Ø19mm
RQP exelent
monté sur rallonge de 1metre entre mon conditionneur secteur et ma barrette secteur monté en furutech basic servant video et alimentation ifi .dynamique, timbre excellent dynamique très bonne et surtout transparence a tous les étage autant audio que video.. étonnante prise bien construite sans chichi.. recommander pour appareils non gourmande en énergie.. idéal pour y brancher des appareils fonctionnant 5/9/12v. et la box tv et tv 4k sans probleme.. couleurs brillante et bruit en recul. Bonne définition. et même l audio de la box y gagne .. câble oayde 3.3mm2 up occ acheté ici.. rien a redire
Functional, well-engineered, neat industrial design
If you wish to invest in a fairly-priced, well-engineered IEC mains plug that accepts weighty-gauge wire, this Viborg plug should not disappoint. As to sonic character, it gels well with OCC copper and non-teflon dialectrics such as PET/PVC, presenting a neutral, dynamic, full-frequency result. Recommended!
Top
Très belle prise d'une très bonne qualité de fabrication, très satisfait.
This IEC C15 Viborg VF503S high-end connector uses high quality materials to provide the best possible electrical conductivity. Thus, the contacts...
