WATTGATE 320 EVO Connector IEC C15 Cryo Treatment Ø 19mm Black
WATTGATE 320 evo Black IEC Power plug Ø 19mm
Wattgate, the international reference manufacturer of mains connectors, offers cryogenically treated IEC connectors for improved conductivity. This robust fiberglass chassis can accommodate the most sophisticated cables whose diameter is often incompatible with conventional power outlets.
Reference : 9539
36,90 €tax incl.
30,75 € tax excl.
Available
Shipping date: 26-09-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Wattgate 320 EVO
Connecteur IEC C15 Traitement Cryo Ø 19mm Noir
With an insertion ring limiting the diameter to 19mm, and a cable clamp to complete the integration, the 320 evo can easily accommodate cables with a large cross-section. The internal connection terminals also deserve attention: equipped with large fixing screws, and therefore not requiring any soldering, they are capable of receiving conductors of large diameter which they ensure a firm hold over a particularly large contact surface. Finally, we will appreciate the small diagram directly engraved in the socket, which gives information on the optimal length of cable to strip.
Efficient and performant
Convenient connector
The connector contact points can accommodate large cables up to 8AWG. The screw system allows quick and easy assembly.
Smart design
The connector design maximizes the contact rate with a clamp and spring system for optimum conductivity. It also allows a firm and reliable fixing of the cables.
Wattagate traitement cryo
Cryo treated
This Wattgate connector benefits from the Cryo treatment developed by the brand, the Deep Cryogenic Treatment (DCT) method. This is a cryogenic treatment with nitrogen that must follow a very specific cycle in order to increase conductivity. In this method, the brand takes care never to put in direct contact the part treated with nitrogen in order to avoid thermal shocks. This process takes 4 to 5 days to achieve an exceptional result.
Dimensions
Connector typeIEC C15
Max cable diameter19mm
Acceptable cable section8 to 14AWG
Current / Voltage10A / 250V AC
15A / 125V AC
15A / 250V AC
Body materialPolycarbonate
Cryo treatmentYes - DCT
Connection typeTo screw
Non magnetic materialsYes
Dimensions7.5 x 3.8cm
ColorNoir
MaterialLaiton
PlatingSilver-plated
For cable diameters19
ConnectionScrew
ConnecticMale
ConnecteurC15
Colissimo - TNT - SoColissimo
Wattgate, the international reference manufacturer of mains connectors, offers cryogenically treated IEC connectors for improved conductivity. This...
