WATTGATE 320i Connector IEC C15 Cryo Treatment Perma Lock Ø 16mm Transparent
WATTGATE 320i-CLR Connecteur IEC Transparent 6mm² CRYO
The Wattgate 320i IEC connector is a simple but extremely well designed model. This is an ideal model for anyone who wants to create high-performance power cables with IEC C15 connector. The Perma Lock design locks the screw threads so that they cannot move due to vibration or heat.
3.0 / 5
Reference : 3089
27,90 €tax incl.
23,25 € tax excl.
Available
Shipping date: 24-09-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Wattgate 320i
Wattgate 320i Connecteur IEC C15 Traitement Cryo Perma Lock Ø 16mm
Efficient and performant
Convenient connector
The connector is equipped with screw terminals, allowing quick and easy assembly of cables, not requiring soldering. A simple cross-head screwdriver is enough to fix your cables on the 3 contacts of the connector.
Smart design
The connector design maximizes the contact rate with a clamp and spring system for optimum conductivity. It also allows a firm and reliable fixing of the cables.
Strong handle
The back of the connector benefits from a cable clamp adaptable according to the diameter used. This holds the cable securely in place to protect it during handling. The connector accepts cables with a maximum diameter of 16mm and a cross-section of 10 to 16AWG.
Wattagate traitement cryo
Cryo treatment
This Wattgate connector benefits from the Cryo treatment developed by the brand, the Deep Cryogenic Treatment (DCT) method. This is a cryogenic treatment with nitrogen that must follow a very specific cycle in order to increase conductivity. In this method, the brand takes care never to put in direct contact the part treated with nitrogen in order to avoid thermal shocks. This process takes 4 to 5 days to achieve an exceptional result.
Dimensions
Connector typeIEC C15
Max cable diameter16mm
Acceptable cable section10 to 16AWG
Current / Voltage250V AC 10A / 125V AC 15A
Body materialPolycarbonate & Nylon
Cryo treatmentYes - DCT
Connection typeTo screw
ColorTransparent
Dimensions72.7 x 38.1mm
MaterialLaiton
PlatingNone
For cable diameters16.8
ConnectionWeld
ConnecticFemale
Section6
ConnecteurC15
Colissimo - TNT - SoColissimo
3 reviews
Je trouve cette IEC d'un bon rapport qualité prix, le système de serrage du cable est tout à fait pertinent et fiable, moins bon pour le serrage des deux parties de la fiche par contre qu'on a du mal à visser jusqu'au bout, bon tourne vie et poigne de rigeur, bien sûr les Furutech gardent l'avantage de la qualité de fabrication qui a un cran d'avance, mais la wattgate fait de ce côté aussi bien qu'une Yarbo ou Elecaudio, avec un petit plus à l'écoute et un excellent système de serrage des cables. Le laiton réussit bien aux fiches secteur je trouve, et dans cette version cryo la définition y gagne. En comparaison la Furutech cuivre donne un rendu fluide mais moins ouvert.
This review has been posted for WATTGATE 320i Connector IEC C15 Cryo Treatment Perma Lock Ø 16mm Transparent
fiche iec a èviter ,d une qualiter de fabrication douteuse ,furutech bien meilleur .......
Connecteur iec bonne dans l ensemble ,mais qualiter de finition et d utilisation inferieure a une yarbo ou furutech ,pour le prix une yarbo fera largement l affaire.
The Wattgate 320i IEC connector is a simple but extremely well designed model. This is an ideal model for anyone who wants to create...
