WATTGATE 320i HC Connector IEC C19 US Format Cryo Treatment Ø16mm Black
WATTGATE 320HC-BLK Connecteur IEC 20A Noir Format Américain
The IEC Wattgate 320i HC connector is a simple but extremely well designed model. This is an ideal model for anyone who wants to create high-performance power cables with IEC C19 (US Format) connectors. The Perma Lock design locks the screw threads so that they cannot move due to vibration or heat.
Reference : 3500
34,90 €tax incl.
29,08 € tax excl.
Shipping from France
Billing in France
Technical support in France
Wattgate 320i HC
IEC C19 Connector US Format Cryo Treatment Ø 16mm black
Connecteur IEC C19 Format Américain Traitement Cryo Ø 16mm Noir
Efficient and performant
A convenient connector
The connector is equipped with screw terminals, allowing quick and easy assembly of cables, not requiring soldering. A simple cross-head screwdriver is enough to fix your cables on the 3 contacts of the connector.
Smart design
The connector design maximizes contact for very good conductivity and effective cable retention.
Strong handle
The back of the connector benefits from a cable clamp adaptable according to the diameter used. This holds the cable securely in place to protect it during handling. The connector accepts cables with a maximum diameter of 16mm and a cross-section of 10 to 16AWG.
Wattagate traitement cryo
Cryo treatment
This Wattgate connector benefits from the Cryo treatment developed by the brand, the Deep Cryogenic Treatment (DCT) method. This is a cryogenic treatment with nitrogen that must follow a very specific cycle in order to increase conductivity. In this method, the brand takes care never to put in direct contact the part treated with nitrogen in order to avoid thermal shocks. This process takes 4 to 5 days to achieve an exceptional result.
Dimensions
Connector typeIEC C19
Max cable diameter16mm
Acceptable cable section10 to 16AWG
Current / Voltage125V AC 20A / 250V AC 20A
Vody materialPolycarbonate & Nylon
Cryo treatmentYes - DCT
Connection typeTo screw
Dimensions7.3 x 3.8cm
Max cable diameter (mm)16.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C19
The IEC Wattgate 320i HC connector is a simple but extremely well designed model. This is an ideal model for anyone who wants to create...
