WATTGATE 320i IEC C15 Connector Cryo Treatment Perma Lock Ø16mm Black
WATTGATE 320i IEC C15 Connector Cryo Treatment Perma Lock Ø 16mm
The Wattgate 320i IEC connector is a simple but extremely well designed model. This is an ideal model for anyone who wants to create high-performance power cables with IEC C15 connector.
Reference : 2880
27,90 €tax incl.
23,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
Wattgate 320i
Wattgate 320i Connecteur IEC C15 Traitement Cryo Perma Lock
The Wattgate 320i IEC connector is a simple but extremely well designed model. This is an ideal model for anyone who wants to create high-performance power cables with IEC C15 connector. The Perma Lock design locks the screw threads so that they cannot move due to vibration or heat.
Practical and efficient
Practical connector
The connector is equipped with screw terminals, allowing quick and easy assembly of cables, not requiring soldering. A simple cross-head screwdriver is enough to fix your cables on the 3 contacts of the connector.
Intelligent design
The connector design maximizes the contact rate with a clamp and spring system for optimum conductivity. It also allows a firm and reliable fixing of the cables.
Strong cable handle
The back of the connector benefits from a cable clamp adaptable according to the diameter used. This holds the cable securely in place to protect it during handling. The connector accepts cables with a maximum diameter of 16mm and a cross-section of 10 to 16AWG.
Wattagate traitement cryo
Cryo treatment
This Wattgate connector benefits from the Cryo treatment developed by the brand, the Deep Cryogenic Treatment (DCT) method. This is a cryogenic treatment with nitrogen that must follow a very specific cycle in order to increase conductivity. In this method, the brand takes care never to put in direct contact the part treated with nitrogen in order to avoid thermal shocks. This process takes 4 to 5 days to achieve an exceptional result.
Dimensions
Connector typeIEC C15
Max cable diameter16mm
Acceptable cable section10 to 16AWG
Current / Voltage10A / 250V AC
15A / 125V AC
Body materialNylon and polycarbonate
Cryo treatmentYes - DCT
Connexion typeTo screw
Dimensions72.7 x 38.1mm
Max cable diameter (mm)16.5
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Très bonne fiche iec, donne de la matière et de l'ouverture. Serrage un peu difficile, il faut de la patience et faire attention aux détails lors de l'assemblage. Sinon rien à signaler, Audiophonics toujours au top!
This review has been posted for WATTGATE 320i IEC C15 Connector Cryo Treatment Perma Lock Ø16mm Black
The Wattgate 320i IEC connector is a simple but extremely well designed model. This is an ideal model for anyone who wants to create...
