BALS Schuko Type E/F Power Connector 250V 16A Ø15mm Black
BALS Schuko Connector 250V 16A Ø 15mm Black
4.8 / 5
Reference : 3164
6,50 €tax incl.
5,42 € tax excl.
Shipping date: 02-04-2024.
Shipping from France
Billing in France
Technical support in France
This connector is constructed as an armored cabinet.
These three solid nickel-plated brass blocks are the "heart" of the plug.
The screws are very large and offer excellent pressure and therefore resistance as low as possible.
A sleeve, an integral part of the case, protects the cables from all cuts and offers an anti-fold protection
Cables of 15mm OD are compatible.
Overall, a solid grip, with a smooth coating.
Characteristics :
  • Connector Schuko 250V 16A
  • Maximum cable diameter (excluding gearbox): 15mm
  • Acceptable cable diameter (with gearbox): 6 - 13mm
  • Conductor diameter: 3.5mm
  • Overall Length: 110mm
  • Overall Diameter of Connector: 41mm
  • Contact Brass Plated Nickel
  • Black color
Max cable diameter (mm)15.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Contacts Plating (Connector)Nickel
Rated current (A)16.0
18 reviews
Un bon produit.
Solide, massif...très pratique pour serrer les câbles dénudés et quant dispositif de serrage de la gaine, il est exemplaire...
This review has been posted for BALS Schuko Type E/F Power Connector 250V 16A Ø15mm Black
Excellente schuko
Très bonne fabrication et serre câble efficace. A l ecoute spectre large et beaucoup d ouverture. Curieusement s avere nettement meilleure que la Bals73 qui équipe le cable Olflex CY 110
AU TOP
Très BON SERRAGE
maintient dans la prise au top
rapport Q/P IMBATTABLE
Robuste
une prise schuko facile a monter et rapport qualité prix excellent
delifi
Connecteur secteur de bonne qualité à un prix imbattable, facile à monter, bons contacts. Le principe de serrage du câble est excellent mais rend la prise peu longue.
