FURUTECH FI-E11-N1 (R) Schuko Type E/F Power Connector Non-Magnetic Rhodium Plated Ø20mm
FURUTECH FI-E11-N1 Connecteur Schuko Amagnétique Rhodium Ø20mm
3.8 / 5
By buying this product you get 27 loyalty points
Reference : 5885
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
This superb type CEE7-VII high-performance Schuko connector has been built with outstanding care Each of itsmetal parts is treated with FURUTECH Alpha Process (Super Cryogenic Treatment and demagnetization).
It has two polarities + an earth connector for a rated voltage of 250VAC with a current of 16A.
Its drivers are made of Alpha treated phosphor bronze for optimum conductivity. The whole set of conductors is protected by a glass fiber body and a strong polycarbonate shell.
DriverPhosphor bronze
Treatmentα (Alpha)
BodyNylon / fiberglass
Shell
Polycarbonate
Cable diameters acceptedfrom 6.6 to 16.0 mm
20 mm with longer screw (not included)
Clamp Stainless (painted black) + stainless steel screws (M4 x 20 mm L)
Dimensions48.2 mm (body length) x 39.0 mm (diameter) x 88.0 mm (total length)
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)16.0
4 reviews
Du rodhium mais..
cette fiche secteur furutech est de bonne fabrication. Mais dommage que la prise est du bronze phosphoré en gros un mélange d'étain et de cuivre recouvert d'un plaquage rodhium. Donc pas de cuivre pure à la base.
Sur plusieurs test avec divers câbles secteur haut gamme il ne faut pas trop pousser le volume il devient un peu criard sur la plupart des câbles testé. Mais il garde une certaine rapidité, et une meilleur définition à l'écoute.
This review has been posted for FURUTECH FI-E11-N1 (R) Schuko Type E/F Power Connector Non-Magnetic Rhodium Plated Ø20mm
la page internet audiophonics un vrai relooking
la page du site internet audiophonics un vrai relooking super bien présenter la classe merci audiophonics rien à dire vraiment Bien à mon gout .
Après 1 an de service (utilisation réduite), je peux dire que le rodage a été un peu long... mais avec un Yarbo 1000 (plutôt adapté aux sources) il y a du silence et de la granularité dans les aiguës... l'ensemble à bluffé un autre fan qui était venu avec son propre câble de grande marque.
Je vais essayer l'alpha 3 avec les connexions primés (FI 38)...
Optez plutot pour les connexions classiques, le son est trop métallique...
