FURUTECH FI-E38 (G) Connector Schuko High-End Gold Ø 17.5mm
FURUTECH FI-E38 (G) Connecteur Schuko High-End Gold Ø17.5mm
8877
94,00 €tax incl.
78,33 € tax excl.
Available
Shipping date: 19-01-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Schuko mains plug very high performance, ideal for the construction of an Audiophile mains cable without compromise.
In addition to its contacts
Copper plated Rhodium , the FI-E38 also benefits from the proprietary anti-magnetism treatment FURUTECH Alpha α, which involves 2 steps:
1-Cryogenization of metals by -250 ° C with the aid of liquid nitrogen in order to consolidate their molecular structure and to improve their conductivity significantly.
2- Submission of these same metals to a powerful magnetic field created by means of magnets arranged in rings and whose attraction force is constantly controlled so as to leave no residual magnetic at the end of the treatment.
The FI-E38 also takes advantage of the patented technology "Floating Field Damper System"which makes it possible to eliminate almost entirely the creation of micro-magnetic and electrostatic turbulence zones internally of the plug, disturbances generated by the passage of the current in the vicinityof certain sensitive component parts (metal fixing screws, cable clamping elements, etc.).
These "floating" field micro-fields conflict with the much more powerful primary magnetic flux generated by the current flow through the cable and the connectors, thereby inducing a form of electrical resistance detrimental to conductivity, generate a form of distortion.
FURUTECH manages to master these phenomena by connecting all the metal parts concerned with each other by means of a conductor charged with bringing all these undesirable energies to the earth.
His bodyof composite material nylon and fiberglassinjected from carbon particlesit demonstrates extreme resistance to shocks, electric arcs and high temperatures.
The conductors are fixed by means of3 screws (2 poles + ground) marked with color code and whose firmness of maintenance, obtained thanks to the technology FURUTECH "Wire Clamp", makes it possible to exclude any risk of tearing or accidental deterioration of the cable, while significantly improving the contact surface.
Compatible with cables in the section is included between 6 and 17.5mm in diameter .
Features:/ Strong>
  • contactsCopper Pure Gold Plated
  • Trai magnetism FURUTECH Alpha α .
  • Technology Owner "Floating Field Damper System"
  • Nylon Body & Fiberglass Injected Carbon Particle
  • Screw plug (3 screws marked with color code)
  • Patented "Wire Clamp" Cable Tightening Technology (Improved Contact Area of ​​17%)
  • Compatible with Cables with a diameter between 6 and 17.5mm
  • Body Length: 90.5mm
  • Body Diameter: 39.6mm
  • 250V / 10A - 125V 15A
https://www.audiophonics.fr/images2/8877/8877_furutech_FI-38G_connector_1.jpg
https://www.audiophonics.fr/images2/8877/8877_furutech_FI-38G_connector_3.jpg
https://www.audiophonics.fr/images2/8877/8877_furutech_FI-38G_connector_4.jpg
">https://www.audiophonics.fr/images2/8877/8877_furutech_FI-38G_connector_2.jpg
https://www.audiophonics.fr/images2/8877/8877_furutech_FI-38G_connector_5.jpg
https://www.audiophonics.fr/images2/4754_FURUTECH-FI-E38(R)_4.jpg
https://www.audiophonics.fr/images2/4754_FURUTECH-FI-E38(R)_3.jpg
MaterialCuivre
PlatingGold-plated
For cable diameters17.5
ConnectionScrew
ConnecticMale
FormatType E
Colissimo - TNT - SoColissimo
3 reviews
trés bonne fiche secteur
Bonne fiche secteur sur mon câble Nanotec excellent musicalité.
This review has been posted for FURUTECH FI-E38 (G) Connector Schuko High-End Gold Ø 17.5mm
May be the best schuko plug ever made
A way to come deep into the music and get rewarded with every little nuance / detail in the play back *****.
prise secteur furutech cuivre pur
prochain commande prise secteur furutech cuivre pur à testé bientôt ? merci .
