YARBO GY-903CF-G Schuko Type E/F Power Connector Red Copper Copper Ø18mm
YARBO GY-903CF-G Power Connector Schuko Carbon Red Copper Ø15mm
The Yarbo GY-903CF-C Schuko Power Connector offers high quality construction.
Reference : 16626
69,90 €tax incl.
58,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
yarbo gy-903cf-c
Schuko connector Red Copper Ø18mm
16626 - Yarbo
The Yarbo GY-903CF-C Schuko Power Connector offers high quality construction. Thanks to its red copper connectors, the electrical signal is transported perfectly and evenly.
The robust body is made of aluminium and carbon.
The connector accepts cables up to 18mm in diameter. The assembly is done by means of a simple screwing system.
The body of this connector has an insulating coating but it is made of aluminium, and therefore conducts current. It is essential that the 2 BTR screws that hold the cable in place are in contact with the shielding and therefore the earth in order to protect you if one of the conductors comes loose and touches the body.
Technical specifications
Type of productSchuko plug
Contact materialRed Copper
Type de montageType of mounting
Cable diameter compatibleØ12-18mm
Max. conductor diameterØ4.5mm
Voltage / Current250V / 15A
general
DimensionsØ39 x 85mm
Net weight130g
ColorSilver / Black
Max cable diameter (mm)18.0
Mounting typeTo screw
ConnecticMale
ConnectorSchuko
Rated current (A)15.0
