FX-AUDIO D2160 MKII FDA Amplifier Bluetooth 5.0 Class D TAS5614 2x100W 4 Ohm Silver
FX-AUDIO D2160 FDA Amplifier Bluetooth 4.2 Class D TAS5614 2x65W 8 Ohms
FX-Audio returns with a new Full Digital Amplifier (FDA): the D2160. This one is directly following its older brother, the FX-Audio D802C, proposing notably more power, audio performances always excellent and functionalities more accomplished.
4.7 / 5
Reference : 12830
249,00 €tax incl.
207,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
FX-AUDIO D2160 mkii
FDA Amplifier Bluetooth TAS5614 2x100W 4Ω
fx-audio d2160
FX-Audio returns with a new Full Digital Amplifier (FDA) : the D2160 MKII. This one is directly following its big brother, the FX-Audio D802C, proposing notably more power, audio performances always excellent and functionalities more accomplished.
TAS5614 & Quality components
The FX-Audio D2160 is based on a TAS5614 amplification chip . This allows this FDA to provide 2x60W at 8Ω or 2x100W at 4Ω. It provides clear and precise sound, while offering deep bass. Thus, the amplifier provides an SNR of -103dB, a THD of 0.01% and a frequency response of 20Hz - 20kHz. The TAS5614 is backed by a STM32 microcontroller (MCU)
Also included in this amplifier is a CM6642 USB chip, an ADC TI PCM1808 for the analog input, a Maxim MAX9722 amplification chip for the headphone output, and AKM AK4118 Toslink coaxial / optical receiver.
Bluetooth : Your music from your sofa
Equipped with a Bluetooth 5.0 CSR8675 chip especially designed for audio, the FX-Audio D2160 will allow you to enjoy your music directly from your sofa. A simple pairing of your reading device (smartphone, tablet ...) to your amplifier and the music starts.
Furthermore, the Bluetooth chip standard 5.0 and its A2DP protocol ensures higher transmission speed and greater stability for better quality audio reproduction. More than that, the chip integrates the technologies aptX and aptX Low-Latency, aptX HD & LDAC, allowing a support up to 24bit-96kHz.
An antenna supplied with the camera is attached to the rear to extend the transmission distance.
Effective audio features
The FX-Audio amplifier offers simple but very effective audio features. With its DSP TAS5548 , the device proposes to modify the bass and treble curve. A "HiFi" mode is also present, corresponding to a Direct Audio mode to bypass the DSP and enjoy a perfect respect of the original signal.
Complete connectivity
The D2160 offers a complete connection that will allow you to connect your system without worry. We thus find in input a Toslink Optics, a Coaxial, a USB-B and a Stereo RCA. An outlet can also connect the antenna to enjoy a greater transmission distance.
Audio Output
On the output side, nothing could be simpler since we find on one side connectors accepting banana plugs to connect your speakers, a subwoofer output on RCA and on the other side a 6.35mm jack connector to connect headphones.
FX-Audio D2160 Connectique
Remote control
It would be a shame to be able to stream your music directly from your couch but having to get up to change the source or adjust the volume, right? FX-Audio has thought and provided with the amp an IR remote control. This will allow you to access all the features of your device, namely control of volume and sources, adjusting the bass and treble or switching to "Hifi" or "Mute" mode.
A simple and strong design
The FX-Audio offers with its D2160 a simple design that allows it to integrate seamlessly into the vast majority of audio systems, while unveiling a stronger side with the integration on its sides of two heatsinks . Heatsinks that are also not irrelevant since they allow the amplifier to effectively evacuate the heat released.
With a 100% brushed aluminum housing, the amplifier promises to be robust and will perfectly protect the internal components of the dust.
FX-Audio D2160 review by Qobuz
" FX-Audio offers us two amplifiers in one. In Tone On mode, a device with a more or less modular restitution, a little round, softened and more or less convincing, it is up to everyone to decide. In Hi-Fi mode, a device with a sharp sound reproduction, as close to the signal as we like, and to which we would have granted our reward. "
Test Qobuz
Amplifier typeFDA (Full Digital Amplifier)
Amplifier chipTAS5614
MCUSTM32
DSPTAS5548
SPDIF ChipAK4118
USB ChipCM6642
Bluetooth chip CSR8675
Headphone amplifier chipMAX9722
Power2x60W at 8Ω / 2x100W at 4Ω (@ THD 10%)
SNR-103dB
THD0.01%
Frequency response20Hz - 20kHz at -2dB
Headphone output power60mW at 32Ω
Headphone output SNR-93dB
Headphone output THD0.02%
Connectors : Inputs
USB-B1x (OTG)
Optical1x
Coaxial1x
RCA Stereo1x
Bluetooth-
Connectors : Outputs
Borniers enceintes-
Headphone connectorJack 6.35mm
Subwoofer output-
Power supplyJack DC 5.5/2.5mm
DC 36V 6A (included)
Dimensions (without antenna)23.8 x 19.5 x 4.5cm
Weight1840g
ColorSilver
Package1x Power supply adapter
1x male USB-A to male USB-B
OutputJack 6.35mm
OutputSpeaker terminal
ColorSilver
Channel2 (Stereo)
Power (W)65.0
Remote ControlYes
13 reviews
Le FDA gagne en naturel
Je possédais jusque-là, en plus de plusieurs amplificateurs à tube et à transistors, trois autres amplificateurs Full Digital (FDA) : un I.AM.D V200, un FX-Audio D802C et un SMSL A18. Je m’en sers sur plusieurs installations, mais en particulier sur des grosses enceintes GKF SVP 505 (haut rendement, aigu/medium à compression et pavillon, grave 38 cm). Je trouvais le D802 un peu agressif, même si spectaculaire pour son prix. Le A18 était plus musical, mais manquait de précision en comparaison. J’étais surtout content du compromis du V200, très « moniteur » sans être trop dur, plus tenu dans les basses que le D802, et un tout petit peu plus transparent dans les aigus (même si c’était très proche). Mais la bonne réputation du D2160 m’a donné envie de voir si je pouvais obtenir encore mieux d’un Full Digital Amplifier sur mon installation.
Avant de parler du D2160, rappelons que la force des FDA, c’est d’être de sortes de DAC de puissance, et donc de coller très précisément au signal numérique d’entrée. Cet avantage est un vrai défaut quand l’enregistrement écouté est médiocre, rien ne le sauve, on entend tout ce qui ne va pas alors qu’avec des amplis plus traditionnels, en particulier à lampe, l’écoute est adoucie par la coloration analogique (le même genre de phénomène qui fait que beaucoup de gens préfèrent aujourd’hui l’ambiance feu de bois des disques vinyle à la rectitude du CD). Bref, le FDA, c’est neutre et transparent et donc intraitable avec les mauvais enregistrements mais incroyablement précis avec les meilleurs. On a en fait même souvent l’impression que c’est trop précis jusqu’à perdre en naturel.
Et bien le D2160 MKII est bien un FDA pour ce qui est de la précision, surtout en mode Hi-fi (touche Direct) associé au mode High Gain (deux secondes sur la touche Direct). Mais, par rapport à mes autres FDA, dès les premières écoutes, le D2160 franchit un vrai cap dans le naturel des timbres. La musique coule toute seule, avec cette musicalité qui fait que j’écoutais certains titres plutôt sur mon vieil ampli à lampe (mais au prix d’une perte de netteté et de précision, malgré un excellent DAC). J’ai retrouvé ce sentiment de naturel avec le D2160 sur tous les enregistrements de musique que j’ai testé aujourd’hui : baroque et classique (voix, orchestre, orgue), jazz, titres très variés de pop et de rock, et même sur de la grosse musique qui tape. Car pour taper, le D2160 tape. Quelle solidité dans les basses ! Les HP 38cm de mes enceintes sont tenus avec une fermeté que je n’avais jamais expérimentée, même en classe A.
Je vais multiplier les écoutes comparatives, mais je suis déjà quasiment sûr que le D2160 va devenir le nouvel amplificateur principal de mon installation. À ce prix, on ne peut que le recommander aux amateurs de transparence et de précision.
PS : Arrivé avec une panne d'écran, l'amplificateur a été remplacé sans frais et rapidement par Audiophonics. Merci !
This review has been posted for FX-AUDIO D2160 MKII FDA Amplifier Bluetooth 5.0 Class D TAS5614 2x100W 4 Ohm Silver
Importance du gain ! (et modification avis précédent)
Je suis l'auteur de l'avis modéré sur cet ampli en raison principalement du rendu des graves...
En lisant, relisant les avis sur ce site et globalement sur le net, pour trouver une solution (alimentation, etc...), je me suis rendu compte que j'utilisais l'ampli en mode Low Gain.
Le passage en mode High Gain (3 sec sur touche Direct) améliore énormément le résultat, et ceux sur l'ensemble du spectre :
Les aigus/mediums sont encore un peu plus précis, on gagne en détails, en subtilité...
Et les graves, qui sont très fades en mode L-Gain, gagne ENORMEMENT en densité, et en subtilité (distinction claire du haut grave et bas grave, belle tenue du grave, etc...) il en fait pas des tonnes, mais bien suffisamment et surtout proprement... on est pas encore au niveau d'un ampli classe A/B à 1000€... mais c'est tout à fait normal !
Désormais je suis ravi de cet ampli qui pour 250€ est un superbe rapport Q/P...
Je pense simplement que le constructeur ne devrait pas proposer le L-Gain sur son produit, et encore moins le programmer par défaut en sortie usine...
Bon je retourne à mon exploration musicale...
Bon rapport qualité/prix - graves pas top
Premier pas dans le monde de l'amplification numérique.
C'est un bon rapport qualité prix au regard de toutes les connexions proposées et la taille très réduite de l'ampli.
Maintenant coté son, je suis plus mitigé :
Les aigus et mediums sont vraiment superbes : le côté analytique des amplis numériques donne une impression de précision et d'espace entre les notes, ça donne un coup de jeune à beaucoup d'enceinte de moyen de gamme...
En revanche les graves sont très médiocres : d'une part en retrait mais surtout brouillons, mal définis..
Pour un système audio d'appoint, ca fait le job mais pour moi niveau son ça ne tient pas la comparaison avec un ampli audio classique... (qui pour un prix légèrement supérieur sera 10 fois plus gros avec 2 fois moins de connectiques)
FX-AUDIO D2160 MKII en USB et HDAUDIO
Merci à Audiophonics pour la livraison rapide...
Merci à Qobuz pour la revue du D2160...
Merci aussi à FX-AUDIO pour ce nouvel ampli FDA qui surpasse largement les précédents.
J'avais déjà acquis un 802 puis un D302, mais limités tout 2 en USB.
Ce qui n'est plus le cas du D2160 !
Directement en USB jusqu'à 192 KH, un régal !
Limpide, efficace, puissant, plus net, plus fin, plus clair, plus propre.
Sade sur l'album Love Deluxe est dans la pièce.
Quelle surprise à l'ouverture, le bloc est d'une belle facture mais pèse aussi son poids.
La télécommande est elle aussi plus sympa.
Je ne l'ai reçu que cet après-midi et il me reste encore beaucoup à tester, comme la sortie casque, ou le branchement de ma platine vinyle.
Pour l'instant, j'écoute, la simplicité épurée d'un son amplifié en FDA sur nouveau compagnon de mes Cabasses SAMPAN M2...
Simple et efficace
Je suis bluffé par la qualité de restitution - utilisé en BT avec des cables Atohm zef et des enceintes Triangle Comète EX : vraiment un achat sans regret.
Seuls bémols : les réglages ne sont pas mis en mémoire (mais la simplicité est telle que leur restauration à l'allumage est très rapide) et la connectique enceintes un peu sous-dimensionnée pour connecter les câbles Atohm de 2,5mm2.
Mais quel son !
FX-Audio returns with a new Full Digital Amplifier (FDA): the D2160. This one is directly following its older brother, the FX-Audio D802C,...
